Gaming Keyboard and Controller Latency
Phen8210
https://gamepadla.com/
A very good site for controller latency references
I always use this site that's why I got the Ultimate 2C 2.4GHz Wukong Edition from 8BitDo's official Taobao store for just over S$20.
It has the best stick and button latency, about 5ms for both, and both running at 1000 Hz unlike most other controllers.
The D-Pad is also very accurate and clicky, perfect for fighting games. This makes it two out of four controller I own with an accurate D-Pad. Actually, I sold my other three controllers after getting this one, this is 8bitdo only modern type controller so far, I think they will have a pro version of it.
Yongkit
Doing some test using the Polling software now get to know more on my system how it perform overall. still love the ps5 DualSense Edge better.
Number of test was based on selection "3. 6000" all tested with Left Right stick, except last Horipad Fighthing commander stick using only left stick.
Phen8210
The 8BitDo Ultimate 2 Wireless has released
https://www.8bitdo.com/ultimate-2-wireless-controller/
The Ultimate 2 is expected to destroy every modern overpriced controllers, I got the Ultimate 2C Wireless 2.4 (little sibling) which was 8BitDo first entry level modern controller and it was already performing better than controllers that were double the price, including all previous 8BitDo controllers released before it.
The ultimate 2 will be the fully featured version of its little sibling with 2x larger battery, packing way more modern features, functionality, and even better performance.
Special Features​
  • TMR Joysticks
  • "8Speed" --- Ultra-low latency and stable 2.4G connection
  • 1000Hz Polling Rate (for 2.4G and wired connection)*
  • Fire Ring - RGB lighting joysticks
  • Extra bumpers (R4 and L4)
  • 2 Pro back paddle buttons
  • Trigger mode switch
  • Hall Effect Triggers
  • Tactile bumpers and D-pad
  • 6-axis motion control
  • Turbo function
  • Vibration
  • Support 8BitDo Ultimate Software V2
Compatibility​
  • Windows 10 (1903) or above
  • Android 9.0 or above
Dimension / Weight​
  • 147*103*61.3 mm
  • 246g
Connectivity​
  • Windows: 2.4G or Wired USB
  • Android: Bluetooth LE
Includes​
  • 8BitDo Ultimate 2 Wireless Controller
  • Charging dock
  • 2.4G adapter
  • USB cable
  • Instruction manual
Yongkit
