kelvinti
- Jan 5, 2009
Check her data limit setting in her phone.Tks ekardo she hv ample $$$$ in her account lei.
Is it set to just 1GB or below?
ok i msg her to check. I am not with her. Kum sia ahCheck her data limit setting in her phone.
Can always call her Simba mobile.. free incoming. Lolok i msg her to check. I am not with her. Kum sia ah
She using mom line. Her sis also simba snr I told them check whether they ser data roam ltdShould be auto deduct one. How many line she have?
Anyone tried simba roaming in Vietnam? Saw the Simba Super Roam plan quite worth it.
Standard sms from SIMBA when roaming:She using mom line. Her sis also simba snr I told them check whether they ser data roam ltd
Life is v short. Ai song song kao tuas & Changi.
my friend use it before back in September. Very good.Anyone tried simba roaming in Vietnam? Saw the Simba Super Roam plan quite worth it.
Hi there I’m facing some issues with the network, just change to eSIM
when im back home still ok got 3 bar then suddenly no network since yesterday
anyone facing the same issue?
Queenstown area
If iPhone can use the sim card but Poco cannot, isn't it a problem with the Poco phone?Be careful, duno why my Xiaomi poco on Android dunno why cannot connect to Simba from day2 onwards during roaming in china. Day 1 was ok.
Switch the simcard to apple phone and can connect. Too bad cannot use on my Android phone and also, when on my apple phone, the tether function is turn off for Simba. Making my andriod phone totally useless on the go (can only rely on shop or hotel wifi)
Not the first time I had issue with Simba overseas. My advice is, Use it as a spare, not the main sim
To hotspot on iPhone, have you configured and set up the hotspot function? It is not as straightforward as on an Android phone.
Speedtest app recently added telco and apps down status powered by downdetector. Seem like M1 always has higher user reports then other telco. When i was using myrepublic, after changed to m1 infrastructure, encountered few times of signal bar full but could not receive mobile data.Slow speed I am not worried .I am more worried on no signal or coverage . Because android still to not have this feature of auto switching network to the other sim when one has no signal .
Ohh, didnt notice that hotspot option is disabled in China on SIMBA. Interesting.Then how do you explain that it was working on the first day?
Even so, I suspect it's more of Android issue.
Hotspot option is disabled for Simba on iphone when roaming in china
If its working on day 1, then it should be working still.Be careful, duno why my Xiaomi poco on Android dunno why cannot connect to Simba from day2 onwards during roaming in china. Day 1 was ok.
It's known as special airplane modeSpeedtest app recently added telco and apps down status powered by downdetector. Seem like M1 always has higher user reports then other telco. When i was using myrepublic, after changed to m1 infrastructure, encountered few times of signal bar full but could not receive mobile data.
for iOS devices, you'll need to manually config the Hotspot settings to enable the hotspot option.Then how do you explain that it was working on the first day?
