- Aug 8, 2012
Rare to receive such speeds.SingTel 5G NSA speed, SingTel Shop Jurong Point, Poco X4 GT
Rare to receive such speeds.![]()
Likely, cannot be at home court also cui, then how to sell their products.Same here. I think they have 5G Pico stations in Singtel Shops. But I am not sure.
I am on 4g SIM card with my iPad 12.9 5th gen. I can’t see this option. made an appt to swap my SIM card today. Maybe I should put it off by a year? Is there any adv in using a 5g sim now?![]()
it's under mobile network
That's not bad. 5G SA or NSA?Speedtest from home (Jurong West Area) is also not bad.
Singtel SIM Only Plus 4G plan with 3-month free 5G Access.
XIaomi Poco X4 GT
https://www.speedtest.net/result/a/9640395933
5G NSA.
Same for the test result next to SingTel Shop Jurong Point.
I know the speed is NSA since I am still using 4G SIM Card. I checked in the shop last time and then checked in the kiosk again recently -- I am not qualified for the free 5G SIM Card.
Just to make sure, I turned off SA in phone settings and then tested again. The result is similar to yesterday's result.
usually report lost / damage sim would be faster to get it fix
Yes I see this option from the SIngtel Shop kiosk. But I am not so sure if it is chargable or not.
Anyway, I am happy with NSA now.
After the three month free 5G Access, I may want to continue with the 6 months S$1 5G Access add-on promotion (if it is still available). I will check then if I am eligible for 5G SIM Card replacement at that time.
call hotline and report lost and ask for waiver etc (usually nobody pay for sim card if u open ur mouth to ask)
Thanks for the tip.
Nothing directed at you. Just saying in general.SingTel 5G NSA speed, SingTel Shop Jurong Point, Poco X4 GT
Which server are you connecting to or just automatic?Speedtest from home (Jurong West Area) is also not bad.
XIaomi Poco X4 GT
The ping is still bad. Still not able to go into single digits. Low ping is an advantage for 5G over 4G for consumers.
Having similar experience now. Im using S23 ultra dual sim (Sim 1 singtel 5g), (sim 2 Xero1 4g). Many a times when singtel 5g is weak, my calls to sim 1 gets forwarded to sim2. I put Sim 1 in 4G, then the calls to sim 1 comes to sim 1 as intended.Guys, can I check what happens to your phone when 5G is weak in a particular area? Does the network shut down with asignage on your phone and then turn on again to 5G?
I've a dual SIM Samsung S23 Ultra. Main SIM for DATA is under Singtel and the other one is 4G with StarHub.
About once or twice a day while on 5G, the phone will lose connection. Both SIM cards will showand turn on again within seconds. Network which is on Singtel will show 5G almost immediately.
I spoke to Singtel and they told me it's common as the 5G network might not be stable in my area and the phone is looking for a stronger network.
I thought that if 5G connection weak, the phone will just use 4G seamlessly without disconnecting from the network.
Can anyone on Singtel 5G share your experience, pls. This issue has been bugging me for the last 2 weeks.
