- Mar 9, 2004
Just tried, never heat up on my phone.do you use the DBS app? it also causes the phone to heat up. just encountered it 🫠
the moment I open it the phone heats upJust tried, never heat up on my phone.
This issue (Heat up / Freeze screen) happened before for iPhone 14 and it took awhile for DBS to update the apps.do you use the DBS app? it also causes the phone to heat up. just encountered it 🫠
I'm on the latest ver of the app for sure. it's still happeningThis issue (Heat up / Freeze screen) happened before for iPhone 14 and it took awhile for DBS to update the apps.
I mean last year iPhone 14 launch also got this issue....your apps is DBS latest version but they might not fix it yet.....I'm on the latest ver of the app for sure. it's still happening![]()
Inspection of the iphone is free before purchaseJust double confirmed with the staff at Apple Orchard.
YES, you can purchased Apple Care + on your iPhone even after 60 days and before warranty end. Just walk in and request to buy. You need to send in your phone for them to check and take photos then once it pass their inspections you can purchase the Apple Care +.
Inspection is free of cos.Inspection of the iphone is free before purchase
Apple Care+ ?
then applecare+ is 2 year from the applecare purchase date?
I’m still on the fence about getting AC+.
Is it true that the Face ID camera can fail even without dropping the phone and the repair will be very costly without AC+ ?
But is up to Limited warranty expire right?
Did they mention anything about showing proof of purchase?
where are you getting your info fromI’m still on the fence about getting AC+.
I feel this is best to purchase maybe 1-2 months after 60 days. The purchase is based on your warranty date registered. As long as within 1 yr.
Yup, and only Apple can repair them since it requires proprietary software verification required after repairs made.I’m still on the fence about getting AC+.
Only If you referring to defects due to manufacturing hardware.so effectively. With applecare+. An iphone can have a full 3 years warranty?
Within this one year limited warranty, if problems like Face ID camera fails or other parts like the USB C port got problem, will repair be free or cost the same if I had bought AC+ within 60 days?Only If you referring to defects due to manufacturing hardware.
Before Apple care+ purchased is limited warranty, does not cover accidental damage.
