MagSafe Powerbank
iamclone
Any MagSafe Powerbank users? Share what powerbank you’re using, pros and cons.
using anker maggo 621
https://www.anker.com/products/a1610
Very lightweight. One of the lightest and slim one I can find from reputable brands.
Low capacity of 5kmah and gets pretty hot when charging.
我要买GTR
I have the Apple Magsafe battery pack. Battery capacity is juvenile but heat produced is not super warm. Had the xiaomi one but heats up alot, so sold.
Not a fan of magsafe powerbanks 🤣 Using regular xiaomi 10k mAh with cable now..
Parka
iamclone
 MagSafe battery pack was a bit too steep. But I’ve heard very good review of it.
Soya_Bean
Using the baseus, it’s a little too hot.
Tried the Apple MagSafe battery pack, it’s really much better in terms of heat.
Will get it if they produce it with usb c
Snoweagle
Using the Apple one and is a very good choice for topping up on the go (up to 90%). Too bad Apple pulled it because it still uses the Lightning port to charge. Hopefully they'll re-release it with a USB-C port.
我要买GTR
Dailou will be the first to hoot the USB-C version :D
leongws
How do you find the quality of the Magair power banks? Does it generate a lot of heat during charging?
I’m considering the Magair14 Duo as it also can also charge Apple Watch.
Quality is good and comes with 2 yrs warranty. i normally use it to charge phone with cable. Very seldom uses magsafe to charge. Yes more heat will be generated if using magsafe but i guess that is common.
Kelvin0217
Bought a 3 in 1 Magsafe 10000mAh power bank with a charging base similar to the link below.
The power bank can be used as a phone stand and is also able to charge the Apple watch. When charging the power bank using the base, you can charge the AirPods Pro 2 as well.
So when I reached home, I just put the power bank back to the base to charge the power bank, iPhone, Apple Watch, and AirPods Pro 2. In the morning, I just removed the fully charged gadgets and ready to go out.
https://www.amazon.com/dp/B0C8CBMQY2/ref=emc_bcc_2_i?th=1
iosnewbie
You bought from Amazon US or similar versions from taobao?
Kelvin0217
I bought from Taobao from this seller.
【淘宝】https://m.tb.cn/h.5STp9Xm?tk=tJQ0WcgH9vi CZ3457 「PZOZ适用苹果三合一无线充电器手表s9手机15promax便携移动充电宝applewatch底座iwatch支架磁吸magsafe快充」
点击链接直接打开 或者 淘宝搜索直接打开
ekardo
looks good, how much after adding delivery?
