VIVIFI
007Mi6
100% is on Singtel.
Fast hand fast leg 😃
fan321
vsvs24
I still maintain the point that esim should be for short term use. Like overseas travel sim of that country.
due to replacement fee and other factors.
Good to see progress in this tech solution too.
What is the advantage of esim over physical sim card ? Other than no need to collect the first time ?
crystalnox
If you have an iPhone, that frees up the physical SIM card slot for another line or an overseas SIM when travelling.
xsoldix
To me, other than better security, less prone to physical damage and easily switch between sims,
I dont see much benefits of esims lah.
xsoldix
Use physical for local.
use esim for travel.
Same leh.
local one is more long term and no headaches if you change phone.
crystalnox
Same leh.
That’s assuming you can get esim for travel, physical prepaid sims are usually more value for money and you can get them at any local store in a pinch. What I’m saying is the physical sim slot is much more valuable for travelling.
cay_one
I need a referral code. PM me please. Thank you.
Received 2 referral code. Don't need anymore. Thanks.
