Take Aeroplane: Liquids Rule
lordfa9
Hopefully sifus can help me understand the liquids rule for handcarry luggage
I was under the impression that the rule states that the amount of liquid carried cannot be more than 100ml
So sometimes i will have mouthwash / plain water in 500ml or more bottles, but the liquid inside only a little bit,maybe because i left 1 dose (mouthwash) or just a sip of water
Sometimes I will kenna caught by customs, they will insist cannot even thought the liquid is only a little bit
other times they let me through
I research online and the way the rules are worded seems the rule is specific to the size of the bottle, not the amount of liquid in it; so 100ml full bottle is ok but 500ml bottle with a little bit inside is not
Can someone help to clarify 🙏
dilphinus
capacity of the container
Rxgn
T4 is very strict.
i find t1 to t3 more relax on checking.
therat
Dont be snarky n mean.
Makes u look stupid
Not everyone flies all the time n rules change as well.
but but...
The 100ml rule was imposed in November 2006, after a terrorist plot involving explosives in drinks bottles was foiled.
therat
Anyway 10 bottles of 100ml is a lot.
for ladies who want to bring their whole set of beauty products.
I seen before custom chong gong their whole set of beauty product in their regular size.. more than 100 mil.
luckygal
Serve them right then
GenerationX
You can bring in total 1000ml of liquid onto plane but the size of each container is kept at 100ml.
1) 100ml x 10 bottle(max to 1000ml)
2) 50ml x 20 bottle (max to 1000ml)
Not true. I brought EMPTY 500ML and 1.5ML BOTTLES no issue. I dun use checked in luggage unless I not planning to get out of airport st8 after touch down so I will have to put all in hand carry
I dun like the thought of my luggage might be out there waiting for ppl to take. So if I check in luggage I will go to the belt as soon as I clear custom
carolliang
Yes, you can bring in empty bottle, even 2ltr also can, provided it is "Empty".
We are talking about liquid in bottle. So max is 100ml if there are "something" inside.
dilphinus
It's really interesting that you can do that.
If you both do a Google search, there are many results that will tell you that you can't carry on containers/bottles that are bigger than 100ml.
https://www.narita-airport.jp/en/security/liquid/
https://www.bne.com.au/passenger/pa...ly able to,measures approximately 20cm x 20cm.
https://www.ana.co.jp/en/jp/guide/boarding-procedures/baggage/international/baggage-limit/
reddevil0728
Can you quote which part says that?
because all seems to suggest as long as got something inside cap is 100ml.
but never talk about empty
