HyperOS 2.0
RLWZ21
Why not, huawei promised update for 5 years ago flagship phones to latest version harmony os.
but redmi phones usually give the most 2 major miui udpate with maybe a few models that can have 2 android upgardes, and miui update sometime not really android upgrade as there are some is like miui with the same android with sercurity update the most.
Ctrl_Alt_Del
Because 70+% of xiaomi,redmi phones are odm. The lower end phones firmware are supported by the odm. Only those higher end phones that are designed by xiaomi then able to support for many years.
This years got improvement. Some models got stated during the launch presentation how many os updates support.
hkchew03
13 years, really show that 996 culture is not productive.
Amdk all go home early after finishing their work don’t take 13 years to come up with their own os.
They didn't take 13 years to come out with OS, MIUI was already 13 years old. HyperOS is just to better integrate the whole ecosystem including their future EV. They could have even done it without Android, but market outside China would not accept it with significant less amount of apps.
ZrE0_Cha0s
feels like an slightly upgrade on the visual part with more customization to your liking kinda of thing. but still feels oddly similar to previouse miui os.
rrr2015
only interested in no ads & bloatware :LOL:
UI hardly anything mind blowing for me, i don't do any sort of customization at all.
hopefully someone can explain core/kernel difference that makes hyperos better than miui.
andyhtc
Suspended
It took away many quick access icons on the right top swipe-down system menu. This makes it more unfriendly for me.
kelvinti
Heard hat MIUI RAM management has problem that it terminated all apps at times even when there is still sufficient RAM?
Is that issue being resolved in HyperOS?
Ctrl_Alt_Del
This is common in most china brands china rom. It is due to the super aggressive battery saving policy.
kelvinti
So, can we avoid this problem totally by changing the Battery Saving policy / management? 🤔
Battery juice is my last concern as I can charge it anytime and anywhere constantly.
rrr2015
u can try disable battery saver to manage your app (no restrictions). i think that might some stability issues
Joelleyuan
i thought this one can edit? you can add the functions you want back into the panel isn't it?
what im more interested to know is are we able to uninstall "themes/wallpaper/wallpaper carousel, get apps" all these xiaomi apps?
Ctrl_Alt_Del
Most of the xiaomi apps can be uninstalled since few version ago. Only a few cannot be uninstall like camera, messaging,clock.
Exaita
