VIVIFI
sallybee
1) hi for vivifi, to port-out, do we need to write into help@vivifi.me?
2)or can just go to another mnvo, register. vivifi will be notified of the porting out ,and new telco will take over, automatically?
gapboy
instad
sintel 4g at crowded area :spin:
Haha very normal to have such low speeds during peak congestion. Singtel has good reception but their 4G is overcrowded and very annoying to use when throttled. You will rather just not use your phone.
erwinrommel
Any 5G promotion?
I am using vivifi vibe 100gb for $10 a month but in 4G only. I tried the trial 5G and it’s ok.
dr34mc4st3r
Any 5G promotion?
Can email support ask them options for 5G with your vibe plan. I'm on vibe 4g then sign up 5G one year contract for $16.06 monthly.
Boltstorm
So I'm porting in from GOMO, received my activation e-sim email, should I do activation now or better to do closer to end of the month?
hereiam7788
Zzzzz my porting done, previous Telco ceased and Vivifi is connected.
However esim showing vivifi temp number and I tried calling my old Singtel number, it say no longer in use….. unable to proceed with my banking otp now….
is it resolved?
hereiam7788
remember to activate the port in on vivifi website. it is manually triggered..
thanks for the reminder. i had notice that it is 'not submitted' under the status, and i had manually submitted it.
now just waiting for the esim. :)
it is stated that porting will only start when the sim card is activated.
besides, i should not install the esim profile to iphone until it is fully ported rite? saw previous posts that some are having the temp number stucked or causing problems with imessage etc... I encountered this issue with previous starhub sim as well when i ported in.
hereiam7788
yes, if you scared dont install the esim first, until morning when fully port over..
but i fix the imessage issue stuck on temporary nunber quite easily. jus go to settings>phone>my number and remove it, do not enter any number. the phone will ask you to activate imessage and may be charged.. jus click ok and it is fixed...
icic. ok. thanks for the tips. :)
i think i will wait till the porting is done before i add the esim profile since it is easy to do so anytime.
i will have my zym physical sim inside my phone so i can tell that it is ported over immediately as well.
hereiam7788
Oh because during sign up, there's an option to delivery sim and I cannot get thru next step if I never tick.
But now ok liao cos last night received an email for the esim.
So I had submitted number porting and got the eim QR code, next step is to install the esim profile or wait till my current Singtel network ceased from my iPhone?
so how long does it takes in total when the time u signed up online until the time u received the email about the esim?
