Hope you guys can help me out. I want to do some cycling...mainly casual around parks and pavements across the country, not the adventurous 'chiong sua' sort haha.
I own an extremely old and untouched for very long BMX that has become VERY rusty..the entire handlebar is covered in rust and the frame and chain are also pretty badly rusted. I have also left the bike on the floor in my storeroom for years (!) and hence the tyres have been 'pressed'/flattened down on the same spot...
Do you guys think I should try to 'revive' my old bicycle or will I be better off getting a new one? If I'm to get a new one, would I be able to get a decent casual bike for around SGD200-250?
I am sorry. I have the same problem. I have a MTB with rusty chains and rusty cogs. Should I spray WD40 and scrub it away or just buy new one from Lazada? Spare parts cheap now
if i were you i'd get new chain and cassette/freewheel and make sure install quick link on chain before install on bike? once a while i would remove chain and soak in detergent, dry then reapply new coat of chain oil and having a quick link makes this much easier ^^
Hi I just started into cycling. I just bought cycling accessories at a bicycle shop spent 200 SGD on a helmet (Abus model ACA2 urban i-v2 German made, cost 145 SGD) and 2 bicycle lights ( front and back, magic shine brand $28 each). Is it expensive or worth it?
No comments on the helmet since it affects your comfort level but you can get much cheaper lights at lazada for 7 dollars plus (back light) and 10 plus for front light (better quality ones)
