Singpass App on Custom ROMs
IOKNEE
From what I saw, only this kernel seems to fit your bill of MIUI
https://github.com/clarencelol/kernel_xiaomi_sm6250/releases
my GPay suddenly stopped working again even with PlayIntegrityFix 13.0. After poking around, my phone became soft bricked (auto reboot a few mins after boot complete).
So I took the chance to wipe data (factory reset), flashed kinesis Kernel r2.1, restored apps using SwiftBackup.
I'm new to this KSU thing, and I don't know how to make backing apps and GPay works with this KSU.
Is there any guide somewhere regarding this?
Also, can I still install Magisk modules? LSposed & modules?
SkyShroud
Google is pretty much banning custom rom safety fixes, very sad indeed.
ATM, with KSU, you need to use ZygiskNext plus PlayIntegrityFix, it won't work without Zygisk but if you use Zygisk, singpass and paylah will detect it even with Shamiko. Play Integrity Fix also doesn't seem to work for all phones, at least the author say it doesn't work for Xiaomi.EU.
But of course, is not hard to disable zygisks and whatever through the manager then reboot to use singpass and paylah.
SkyShroud
so what's the advantage of KSU?
Before google start messing around with play integrity
You can use KSU without Zygisk but still have rooting capability while able to use all your singpass and bank apps.
But because google start messing around with play integrity and the fix module only work for zygisk, you don't have choice.
IOKNEE
thanks for the situation update.
maybe i'll stick around with custom kernel + KSU for a while, hoping that there's another workaround for playintegrty.
SkyShroud
There is a non-zygisk, non-magisk, non-ksu solution which is to flash to use different fingerprint.
Download this zip
https://github.com/luk1337/ih8sn
Modify ih8sn.conf in the zip to use this
Code:
BUILD_FINGERPRINT=google/bullhead/bullhead:8.0.0/OPR6.170623.013/4283548:user/release-keys
BUILD_TAGS=release-keys
BUILD_TYPE=user
DEBUGGABLE=0
PRODUCT_NAME=bullhead
Then flash the zip via recovery
Bullhead is a legacy device so unless they drop bullhead, I think they will not ban the fingerprint.
Edit: Doesn't work for MIUI or MIUI.EU rom
vibranze
Download this zip
Code:
BUILD_TYPE=user
DEBUGGABLE=0
By using this, will Google Pay work without PlayIntegrityFix? Thanks.
Update: After patched with ih8sn-armv7a, Google Pay still didn't work on my Mi 13 Ultra with Pixel Experience Plus OS.
vibranze
And Singpass refused to work as long as there are modules installed in KSU. Surprisingly though, after I deactivate all the modules, including PlayIntegrityFix, Google Pay / Wallet continue working without issue.
I found that as long as if Wallet is already setup, even after I disabled the Zygisk-Next and PlayIntegrityFix, Wallet will keep working.
SkyShroud
You suppose to be using aarch64, armv7a is for older device. You can use CPU-Z app and check under system to clarify your device architecture.
Also, make sure to change the ih8sn.conf in the original zip with the new bullhead signature.
SkyShroud
Thanks, it works! But the side effect is I can't browse any websites, they are just showing blank page, same issue when I installed Shamiko. Any idea how to fix this issue?
What modules did you installed? Did you previously use adaway?
spinning_quirK
Not Adaway, but Adguard4Magisk module, I disabled it though while using Shamiko and unmount injector, and I still get a blank page.
Blank page using inbuilt Chrome browser? Or Webview?
I can think of 2 workarounds
1) try private DNS, maybe Cloudflare, Adguard, NextDNS defaults
2) try a 3rd-party browser like Mull, Kiwi, Firefox, Brave, etc
vibranze
Thanks bro.
Followed your workarounds.
1. I am using 1dot1dot1dot1.cloudflare-dns.com as my private DNS - same issue.
2. And I am using Brave as my default browser, with 1.1.1.1 as a secure DNS, turning this off doesn't make any diff.
Tried Chrome, webview - same issue
Firefox and Mull are working fine. Kiwi's not.
Shall I just use Mull or Firefox? But I am so used to Brave. :unsure:
spinning_quirK
Thanks bro.
Or perhaps you can install the injector only when you need to use it, and leave it disabled or uninstalled for the rest of the time?
Strange though, what's in the Chromium sauce that's being affected while the Gecko engine isn't?
vibranze
Yeah, that was my plan until you introduced me a Mull browser hehe, maybe I will just leave it enabled so don't need to reboot when I want to use Singpass. Do you know any screenshot app that can take a screenshot within Singpass app? Thanks.
