Singpass App on Custom ROMs
SkyShroud
Not Adaway, but Adguard4Magisk module, I disabled it though while using Shamiko and unmount injector, and I still get a blank page.
I recall there is a time where those adblock apps via root will modify the hosts file directly, instead of using systemless hosts because it was possible at those time without getting detected. It could be your system hosts is already modified but with recent updates, a systemless hosts is used while not restoring the system hosts to its original state.
To confirm, go to recovery, mount system, and browse to /system/etc/hosts to check. If it doesn't exist, try /system_root/system/etc/hosts
The system hosts should be something like
Code:
127.0.0.1 localhost
::1 localhost
If it isn't like that but instead a super duper long list of ip address, then you have to restore the file to its original state.
https://xdaforums.com/t/editing-host-file.4345167/
vibranze
Code:
127.0.0.1 localhost
::1 localhost
Thanks bro, checked and it is like below. I guess it is not being modified yet?
Code:
127.0.0.1       localhost
::1             ip6-localhost
SkyShroud
Code:
127.0.0.1       localhost
::1             ip6-localhost
Erm.
Use a file manager with root access to see if system/etc/hosts is loaded systemless hosts.
AFAIK, Firefox ignore hosts file on default unless explicitly set otherwise so that is the only reason I can think of when your firefox work but chrome doesn't.
vibranze
Erm.
How to check the hosts file is loaded systemless? I was using MiXplorer to view the content of the hosts file.
IOKNEE
There is a non-zygisk, non-magisk, non-ksu solution which is to flash to use different fingerprint.
Download this zip
https://github.com/luk1337/ih8sn
Modify ih8sn.conf in the zip to use this
Code:
BUILD_FINGERPRINT=google/bullhead/bullhead:8.0.0/OPR6.170623.013/4283548:user/release-keys
BUILD_TAGS=release-keys
BUILD_TYPE=user
DEBUGGABLE=0
PRODUCT_NAME=bullhead
Then flash the zip via recovery
Bullhead is a legacy device so unless they drop bullhead, I think they will not ban the fingerprint.
it seems like PlayIntegrityFix v13.1 is using this. Anyone tried? Should I remove all Zygisk modules after installing PIF v13.1?
Jerry91
Download this zip
Code:
BUILD_TYPE=user
DEBUGGABLE=0
All the custom ROMs right now are giving me headache on my POCO F5.
If I may ask, does this work with MIUI Global ROM to pass CTS Profile? I just tried it and it doesnt seem to work.
I then tried ZygiskNext and PlayIntegrityFix and it works to pass CTS Profile but ksu_unmount_modules doesnt seem to work for SingPass for me.
vibranze
It's not the built-in KSU unmount module but a separate unmount injector module that you have to install. Download it from the link below.
https://github.com/HuskyDG/ksu_unmount_injector
Jerry91
[link]
yes, this is the module I have installed and with the default built-in unmount disabled.
EDIT: ok i know why it's not working as it's for kernels < 5.9, meanwhile mine is 5.10.199
SkyShroud
Fingerprint doesn't seem to work with MIUI rom, I heard because they function differently from mainstream.
Zygisk get detected by Singpass.
Jerry91
Thank you for the details! Also, I suppose MIUI has a failsafe to the system partition as the scripts are gone even after using the push.sh method to install and verifying the file exist in recovery.
Looks like I can only choose to either use GPay or Singpass for now.
IOKNEE
you mean Xiaomi.eu?
IOKNEE
according to user xcl1pse at XDA, the working solution for Singpass app is:
Just need something to hide the manager like HMA
I've asked xcl1pse to join in this discussion but it seems like a no.
I'm on KSU now. Anyone on Magisk can give it a try?
highdiver_2000
Singpass working on the following. Nothing fancy
PixelOS
Standard Magisk
PIF module
Shamiko module
Disable "Enforce DenyList"
Enable MagiskHide
Put Wallet, Singapass, UOB, POSB, Grab, Zig on the DenyList.
I use HMA for Trust
Back to using paywave
Currently broken is HSBC and Citibank. I don't use HSBC and I think I can move Citibank to another phone.
IOKNEE
PixelOS
Standard Magisk
PIF module
Shamiko module
Enable MagiskHide
What do you mean by "standard Magisk" + " MagiskHide"? I though topjohnwu removed MagiskHide a long time ago?
my Singpass doesn't work, although GPay/Wallet, DBS, OCBC, Paylah, McDonald's are ok:
  • Xiaomi Redmi Note 9 Pro Global (joyeuse)
  • MIUI Global 14.0.3 Stable (Android 12)
  • GPay 200.1.1
  • KernelSU 11366
  • Play Integrity Fix 13.8
  • ZygiskNext 4-0.8.1
  • KernelSU Unmount modules 1.11.2
  • Process Monitor Tool 2.3
  • LSposed (Zygisk) 1.9.2
I'm confused because there seems to be mixed results with Singpass app.
For my case, I also use Swift Backup to restore many apps, probably it triggered Singpass error T0, but I'm too lazy to uninstall & reinstall from Google Play Store manually.
spinning_quirK
  • GPay 200.1.1
  • KernelSU 11366
It's a choice between Singpass or Macs. Remove ZygiskNext and the former should pass.
If Momo can detect ZygiskNext, so can Singpass.
