cloudystar
Am I overthinking ? My 15pro max screen protector (full coverage) the bezel looks thick lol
Sekali the shopee seller sold me 14 pro max screen protector instead😅
Switch to camera mode and if you can see the white lines clearly on all 4 corners of the frame then it means the black border is not covering your screen 😎
ragnarok95
Senior Moderator
Senior Moderator
14pm and 15pm same screen size. Only the bezel of the phone is diff.
Charlie_Zhan
https://heyeased.weebly.com/double-screen-border-14promax.html
use this link to download the wallpaper and see if you see 1 border or double border when set as wallpaper. if you only see 1 border. means the SP bezel is too thick and covering part of your screen.
the smartdevil schott SP that i’m using now can let me see double borders. means the SP corner bezels are thin enough to not cover the screen.
or you can use the camera viewfinder 4 white borders method.
but i prefer the wallpaper method because u can see the top and bottom coverage.
Charlie_Zhan
yes so some sellers will sell that SP meant for iphone 14 as iphone 15.
but most of the black bordered iphone 14 SP have thicker bezels that will block your iphone 15 display when installed.
Archuke
i still feel that carbon fibre must have lacquer coating then look nice. rebel is so slow in production that i dont even wanna wait for their clear version anymore. i think by the time the clear is out, few more months iphone 16 out already.
Rubick
Look nice but after awhile will peel off.
my old mous case kena.
when peeling is yucky
