Trans-Am
- Apr 2, 2014
You can port out and port back incan only change from the $10 plan to Super roam Max $25 but cannot downgrade back to $10?
Abit stupid right, idea is to have flexibility for the plan as per usage for the month ahead
Meaning change telco and come back to Simba 1 month later?You can port out and port back in
Anyone using Nighthawk MR1100 device? I'm trying to use Simba simcard but unable to connect to internet on the device itself..
4G/ LTE BandsIt won't work, maybe when they first introduced this device, Simba has not started biz yet.
MR1000 LTE/4G bands:
1, 2, 3, 4, 5, 7, 12, 14, 29, 30, 66
https://www.downloads.netgear.com/files/GDC/MR1100/MR1100_DS.pdf
Simba mainly uses Band 8 and 40. Though they also have Band 38. None of the Bands are listed for MR1000. It is specifically made for M1 plus the other 2 big Telcos that use Band 3 and 7 for their 4G.
https://www.spectrum-tracker.com/Singapore
Works fine in China, seamless.Anyone can advise me on the below mention?
1. For the plan SuperRoam 50GB (30D), the bundled10GB roaming data can i use in China?
2. How is the connection in China (Guangzhou)?
3. no need VPN right?
4G/ LTE Bands
singtel: 3, 7 & 8
M1: 3 & 7
starhubs: 3, 7 & 38
simba: 8, 40
we have only 4 telco. mnvo are sitting on them.Is there any comprehensive list of SG Telco/MNVO band tiers they are using currently?
From ZYM, VIVIFI, Zero1, etc etc..
It is included in the 1GB roaming. I am using it.Works fine in China, seamless.
Have to top up as China is not included in the groups that are bundled in any of the plans for usage.
Yes it’s Same 21 days terms here with unlimited throttled data.read TnC... for $10 sim its 21 days of unlimited data at 0.1mbps after non payment if plan renewal fails.. afterwards line will be terminated..
Simba runs on it's own networkhow is simba reception compared to starhub?
Is simba using singtel network?
I tried to search for Simba reception at home. I only find M1 and starhub (which I am using now)Simba runs on it's own network
