VIVIFI
fan321
let say I got sim 1 and sim2 already loaded and I add esim
can I disabled sim 1 and use esim as Data and sim 2 as normal voice and sms when I'm roaming on Samsung
If u activate esim, then sim 2 will be deactivated. If u activate both sim 1 and sim 2, then esim will be deactivated. That's how my S23Ultra works, not sure abt Oppo N3, will know in 1 to 2 weeks time.
OnePunch!!
so If I want mine sim2 to be act as voice sms I nedd to swap sim 2 sim card to sim 1 and removed sim 1 sim
then esim as Data
uncle_josh
no volte yet right
file
VoLTE is for 4G
VoNR for 5G
OnePunch!!
please don't post wrong thing, Vivifi does not even have VoLTE yet, let alone VoNR
Make a voice call and you will see it change to 3G.
Just because iphone dont have VoLTE icon means its available if you turn it on.
thanks good info
hereiam7788
tell you ready...
but until now the no is not yet ported and very soon i should see the status of number porting failed in system.
damn... porting from ZYM to VIVIFI always failed at once. last year when i port from zym to vivifi, exactly the same problem also. need to contact VIVIFI to get the technical team to fix it.
(somehow i recalled the issue was the first name/last name of VIVIFI is terbalik comparing to ZYM so it will always cause it to fail for the no porting).
hereiam7788
anyone who wants to port no to vivifi better be careful (especially zym). this is the second time i port from zym to vivifi.
if u planned to port out from zym to vivifi, this will happen.
(from what i recalled last year failed experience, it could be due to the first name/last name mismatch in vivifi system).
to resolve this, must email vivifi to get their technical team to fix this which it caused delay.
damn...
(in case, u wonder my zym line was out of signal since last night 11:04pm, zym app also showed my no was gone).
thiamhui
damn...
My turn tonight, from ZYM as well...
Decided to port in earlier after reading your post.
hereiam7788
ported out not an issue. becos ur line will be cut at 11:04pm on the working day u started the porting.
becos the no it out from my zym app. so it should be in time not to cause extra charge at zym side for another month of bill.
hereiam7788
now 10am++, the number porting is shown as success.
i can even receive SMS OTP.
but my no shown under the esim is still the temp VIVIFI no, same for imessages!!!
i tried the method to remove no under my number and leave it blank, but nothing help. restarted the phone multiple also the same...
help!!!!
hereiam7788
oh no... esim can reinsert? i try reinsert physical sim after removing the number in phone settings.. it did work for my iphone8..
turn off imessage anf FACE TIME first... then remove the nunber and save...
cannot reinsert, can only delete it and add again. VIVIFI only allows 3 times usage of the QR code given for esim.
hereiam7788
funny thing is that VIVIFI did not even give me any free 5G trial access while ZYM is free all the time after trial.
