Gaming Laptop
HBK
Hi guys,
I’m thinking of buying a 16” laptop but I’m not sure which GPU should I choose. I’m thinking between 4070 and 4080.
For 4070, I’m looking at the laptop with 3.2K Resolution. Not sure if 4070 can maximise the screen. Will 4080 be overkill for that display.
I’m open to other options.
thanks in advance
Xihe
What’s your budget? Get the highest spec your budget allow. Nothing is overkill if your budget have no limit.
need2hyde
Hi all, hijacked this thread because I didn't want create extra threads.
Got a quote of S2109 for the laptop below:
Legion Pro 5i (16″, Gen 8) (Onyx Grey)
Processor: 13th Generation Intel® Core™ i7-13700HX Processor (E-cores up to 3.70 GHz P-cores up to 5.00 GHz)
Operating System: Windows 11 Home 64
Graphic Card: NVIDIA® GeForce RTX™ 4060 Laptop GPU 8GB GDDR6
Memory: 32 GB DDR5-4800MHz (SODIMM) - (2 x 16 GB)
Storage: 1 TB SSD M.2 2280 PCIe Gen4 TLC
Display: 16" WQXGA (2560 x 1600), IPS, Anti-Glare, Non-Touch, HDR 400, 100%sRGB, 500 nits, 240Hz, Narrow Bezel, Low Blue Light
Camera: 1080P FHD with Dual Microphone and E-camera Shutter
Battery: 4 Cell Li-Polymer 80 Wh
AC Adapter / Power Supply: 300W
Fingerprint Reader: No Fingerprint Reader
Pointing Device: USB RGB Gaming Mouse + ClickPad
Keyboard: 4zone RGB Backlit, Black - English (US)
WLAN: Wi-Fi 6E 2x2 AX & Bluetooth® 5.1 or above
Warranty: 3 Year Legion Ultimate Support
Color: Onyx Grey
Services: 3 Year Accidental Damage Protection
Is it worth it?
j4nfz1981
Color: Onyx Grey
Is it worth it?
Hi, u bought the laptop in the end? I am looking for one atm. Having a lot of sales across different brands. Not sure is it because next gen r coming up. Anw, i read online some users are experiencing crashes from doing light work. Temp workard was to set graphic card to perfomance mode. May i know if u guys face such issues? Has the issue been resolved by updates?
need2hyde
I paid $2079 in the end. Signed up as a Lenovo member and got an additional $30 voucher. Figured I can offset the costs a bit more by selling off the headset and 23.8" monitor that will come with it cos I have no use for them.
So far so good.... No problems playing any games. Not planning to do any work, so not too sure if I will face issues if I try later.
