SIM only plan to recommend?
Hakuna Matata
Gomo as main line.
Simba for data connection.
Simba has issues in receiving OTP SMS.
trevlim
how are all these companies mentioned able to offer SIM plans cheaper than the big 3, green, red and yellow?
sandeay
Use sintel mvno
Heya is quite good.. Gomo is slightly higher price for same thing. Both sintel and has VoLTE. Would not recommend gomo cus a lot of stunt...
Zym, Vivifi, Zero1, Cmlink all no VoLTE as of now. All sintel. all plan quite good come with free malaysia roaming..
M1 maxx also quite value.. $14/200gb but is m1 network, not as bad as simba.. The best feature is its free base plan...
Do not buy simba. too slow and cui already... their 5G network cause more issues than just using their 4G... those tell you is good cus they scared no competition if simba fold... Even a free service like wireless@sg better than simba...
i think a lot depends on where you stay and the places you frequent. I comverted to Simba from M1. And I find Simba much better than M1 in terms of connectivity. But recently when I went Yishun daily as my family member was hospitalised in KTPH, I found the connectivity bad. But luckily I do not go Yishun often as my family member has been discharged.
Gian_Png
I took underground train sometimes. I do not see any disconnection. Are you using Simba?
nope , simba is basically TPG renamed. all the while underground connection is not good from opinions.
those without issues most likely take bus, drive cars or mrt rides above the ground bah. lol
GOMO use to be quite gd lor but must port over thn got discount if not wrong
gomo used to be good till they intro 5G, then 4G became super slow and underground signals is cmi.
gomo sucks now, too many subscribers
u using 4G or 5G?
coyote
u using 4G or 5G?
I took DTL and Circle line. Reception is good. Are you on Simba now or you based on your previous experience? I understood from some longer term Simba users, they actually improved their reception inside MRT tunnels over the years.
Gian_Png
non simba user, based on family member's past experiences, didnt dare to try. :s13: :s13:
previously tried m1, gomo, now on vivifi
improve is not good enough for me i guess , i only using 4G , not willing to pay for 5G.
coyote
Then you are just based on hearsay...nit accurate.
ahnyaahnya
What about Red One ?
My Republic ?
Circles? Someone said this one no good ?
I'm fine with 4G data, and not much GB ( these have only 10GB ones.)
But I want good reception. Have Simba on my spare phone .... sometimes for a short while it gets no reception in MRT tunnel.
PaperRay
Giga... though not the cheapest among the MVNO, it is the most reliable along with GOMO because directly operated by Starhub and Singtel respectively. GOMO is more expensive and worse value than giga in general. Get the $15 50gb plan good enough for the average user.
simba better than gigi at certain area
