Door bell with camera recommendations
spiritnec
Hi guys,
For the eufy dual cam doorbell battery version S330, will the camera still record when the WiFi is down?
Thanks in advance!
sellwatch
Anybody bought lockin catx from Taobao before and managed to connect to mihome sg server?
Tornesoul
depends on your preference.
battery version just needs simple setup to secure the door bell, one may not need to drill.
=> battery charging once every 2.5 months.
=> some house setup, this is an Handy option. I opt for this.
=> charging is not difficult, a simple unlock mechanism is used to bring the door bell out from the mounting bracket.
wired version needs to have wires feed to the door bell and setup transformers to supply AC supply to the door bell.
=> after initial setup, no need to care on power supply.
=> drilling, preparing own transformer may not be a simple job to most. may need to pay $60-80 for the installation work excluding the transformer cost.
how did u mount the google doorbell battery without drilling?
tape? any recommendations?
HMAN
yes just 3M tap on the mounting bracket.
I did make mistake placing too close too the door peep hole, then try to dislodge it but it is super strong to pull it away.
then I am convinced, don't bother to screw in the mounting bracket.
I am in private, less concern on sneaky figures to steal it.
Tornesoul
i see, so
house wall > 3m tape > mounting bracket
surprised it would hold, seems pretty heavy. scared drop then gg
HMAN
i see, so
That doorbell is not heavy, 600g ? I stick it to my door, the mounting bracket like 0.8" x 4" size, plenty of holding area. Won't have issue to hold a weight of 600g with 2 x 4" strip 3M Tape
winningeleven
Hi guys,
Thanks in advance!
I am using wired version. My doorbell is still able to record video when WiFi is down since it has a build in storage of 4gb. The WiFi function allowed users to receive "instant notifications " and video.
cstanhwz
Using the Tapo S230S1 since 17th Dec 2023.
Due to our usage pattern, battery life is now at 43%.
Motion recording on and checking of recordings and liveview occasionally.
Have a spare battery on standby and fully charged to change the battery from the unit when the one in used is low in battery level.
Image quality of the camera is good and so are the recordings to microSD.
Notification is received quite fast (within 2 seconds on 4G data) when the bell is pressed.
Overall, happy with this model and it's function.
Only wished that the view is 3x4 (and wider vertically) instead of 4x3 so that can see the whole person (especially deliveries person when they place the parcel on the floor infront of the gate).
Edit : Just saw this (not available locally).
https://www.tapo.com/en/product/smart-camera/tapo-d130/
winningeleven
using battery or wired? wondering how to connect, cause the existing hdb doorbell wire dont have electricity
Just make use of the wire.
My eufy wired doorbell make use of the "hdb doorbell wire " I use a step-down adapter from my electricty socket and tap it on the wire end, which is exposed on the kitchen wall opening.
elvintay07
What is step down adapter?
dinosaur2776
Used TAPO for 1 year already. Damn good. Movement also alert you. Press doorbell can talk to person. Can record preset messages
dinosaur2776
It is battery powered right? And only cost $80
Ard there. The battery one day 1 percent reduce. So every 3 mths maybe need to charge for few hours. But easy to install and easy to take out and charge
What I like also is that it is quick enough to capture motion for ppl who is walking pass corridor.
elvintay07
They should release a version with power
HelIoo
How is the vertical angle coverage capturing?
