Bui Kia
- Jul 23, 2015
those of us v free at e moment e.g. 5 min or 10 min can do this 2
a) ribbon 2
simple , more cutting and need glue
b) ribbon 1
more origami need tape
! if you are using lkk colorpaper, "right side" of ribbon is on the inside, if not need to redo.
if you r using construction paper then either side is good
on top your post ... @Bowser Jr post about chop kkj
you suddenly post a scissor .....scare me sia
does it help ?
