- Apr 8, 2011
You try then let us know?@xiaofan I went to see my Nokia ONR settings again. I found this. Do you think it will allow me to save the settings?
Is there a setting to disable the management console aka TR-069?@xiaofan I went to see my Nokia ONR settings again. I found this. Do you think it will allow me to save the settings?
Nope. TR-069 is greyed off. Cannot changeIs there a setting to disable the management console aka TR-069?
tks... thats a dealbreaker for me.Nope. TR-069 is greyed off. Cannot change
i just try....not allowed to change to bridge mode.
Based on those test ipv6 website. it says Native IPv6Thanks, when you say IPv6 is working, are you using 6rd or native IPv6 (DHCPv6)?
You'll need to look around in the router's settings to know whether your IPv6 connectivity is via 6rd or DHCPv6. Those test sites can't really tell and are only looking at your ipv6 prefix to determine teredo or native ipv6.Based on those test ipv6 website. it says Native IPv6
On ONR all shows DHCPv6You'll need to look around in the router's settings to know whether your IPv6 connectivity is via 6rd or DHCPv6. Those test sites can't really tell and are only looking at your ipv6 prefix to determine teredo or native ipv6.
Anyone has guide on how to configure Nokia G240 ONR bridged mode?
Also, does anyone knows if Asus router is able to understand the VLAN 10 setting from the ONR?
