NVMe M.2 SSD not detected issue
s3phiria
Hi Senpais,
Building a new PC myself (specs below) and I'm having some issues and few days of Google searching didn't help. Will greatly appreciate any insight/advice!
1) On first boot up into bios, I am able to detect my new SATA SSD and NVMe M.2 SSD in bios but upon reboot to install windows through flash drive, the installer is unable to find any drive to install on.
2) When I then reboot into bios again, I am now unable to find both drives in bios as well. Tried rebooting few more times, updated MOBO bios, ensuring cable connectivity, different SATA ports all didn't work
3) so...I tried installing the NVMe SSD on an old system. And somehow, the same issue arose. On 1st boot, I am able to find the disk in bios but not in windows. And on 2nd boot, it is not detected in bios anymore too. (Have not tried the SATA SSD on old system yet, holding out in case something needs to be done on very first boot..)
4) I then try an old SSD (with windows installed on it alr) on the new system, and got into the same issues again. First seen in bios, but cannot detect in windows (when boot from flash drive to install windows again) then subsequently disappear from bios too.
I initially thought it might be the new Mobo issue..but replicated on old system means the drives are more likely faulty? Or so suay both m.2 slots got issue? I'm quite sure I've mounted them correctly and the m.2 drive is sitting nicely in the slot. Or is the new Mobo locking the SSDs somehow?
Things I've tried:
- "Crucial Storage Executive" does not detect the new NVMe SSD
- HWInfo also does not detect it
- Does not appear in device manager or disk management
- device manager > storage controllers only has "Microsoft Storage Spaces Controller" and no AMD RAID stuff that was found to be problematic in other forums
New system:
CPU: AMD Ryzen 7600X
MOBO: MSI PRO B650M-A WIFI
SATA SSD: Samsung 860 EVO 1TB
NVMe SSD: Crucial P3 Plus 1TB
Old system:
CPU: AMD Ryzen 1700
MOBO: ASRock AB350 Pro4
Old SATA SSD: Samsung 860 EVO 250GB
xonix
@s3phiria , I assume you are trying to install win10 / 11 ?
If the drives were working before you transferred, maybe check your new board socket pins ? ;)
s3phiria
Yes, win10. Now can't even see in bios alr, disappeared though it's there initially ._. want to rage also dno who to angst on, mobo or SSD supplier..
Brand new drives so no idea if they are working. I will check the pins again later..
Replace the SSD if it is under warranty, if newly brought bring back to the shop.
FYI for gaming PC I won't recommend Crucial P3 is a rather weak SSD.
Go for something like Samsung 980 (Non pro), is more ex but at least it is faster than P3.
Thanks! Will look into Samsung if I can refund these, the SATA SSD is alr Samsung and I have same issue though..
You can try -
In the BIOS, disable Secure Boot
I don't rmb seeing this option in the MSI set up screen when I was troubleshooting.. I will check again when I get home tonight and try/revert, thanks!
Koenig168
You might have to select "Advanced" mode.
