animeonegai
- Nov 27, 2003
I only trust outlier and aurava series
Currently have Jabra Elite 4 & Liberty 4 NCHow many of you own more than 2 earbuds?
i have 3.. but i want let go my L3pro. its battery is very bad. I prefer one with long battery life.How many of you own more than 2 earbuds?
The Ace2 sounds good sia
If only Creative have some good promo, 150usd is out of my budget
u can search youtube using the keywordsHi, I'm looking for a replacement for my AP Pro (2nd Gen). I personally find the base, mic quality and transparency are enough for me.
Any recommendation on a cheaper alternative ? (maybe less than $200, in-ear prefer as I will be using for sports)
If anyone tried on Huawei Freebuds 5i and can provide some review would be great.
Check with bose on thisHi, I just got myself the Bose QC2 earbuds and am new to Bose products. I noticed the following:
When I connect the charging case to a wall charger, it does not start charging unless I open and close the case.
Is this behavior normal?
Yes mine does this sometimes also.Hi, I just got myself the Bose QC2 earbuds and am new to Bose products. I noticed the following:
Waiting for promo and reviews too. It seems pretty good.
Sound 4nc have been getting terrific reviews from everyone. I already have life P3 and A40 so don't see the need for 4nc thoughhttps://www.pcmag.com/reviews/creative-aurvana-ace-2
the reviewer compared ace2 with soundcore 4 nc, soundcore 4nc wins.
I have the Soundcore NC4 since launched and got it for $78 or something. They make me question deeply why last time need to spend $300 plus for an ANC earbuds.Sound 4nc have been getting terrific reviews from everyone. I already have life P3 and A40 so don't see the need for 4nc though
if you are in mrt, bus or plane, no choice. passive sound isolation is not good enough.Imo anc itself is also not that necessary, just need a gd seal which is not that difficult to achieve. All the bells and whistle just to Jack up the price. The sound signature and tuning is the most impt aspect
FYI only, passive isolation can be good, if you don't mind using wired iem. I use both wired and wireless, still find better isolation with wiredif you are in mrt, bus or plane, no choice. passive sound isolation is not good enough.
at home or office, can live without anc
what wireless earpiece are you using ?FYI only, passive isolation can be good, if you don't mind using wired iem. I use both wired and wireless, still find better isolation with wired
Granted, unfair comparison, as my wired iem is etymotic, which comes with triple flange tips
