POCO X6 series
Krabs.
tian_yibang
https://nanoreview.net/en/soc/qualcomm-snapdragon-7s-gen-2
Compare with Poco F5 CPU , the old architecture with a78 a55 no fight at all
7s 7plus , big difference in performance
Just wait for f5 get cheaper can liao , skip the x6 base model
https://nanoreview.net/en/soc-compa...-7s-gen-2-vs-qualcomm-snapdragon-7-plus-gen-2
Not surprising at all
POCO X series hv always (most if not all) been one-level lower than the "flagship" F series ma
ie. previously X5 base using SD695 compared with F4 base using SD870 (albeit they recycle same cpu from F3)
Also
as saying goes - Newer doesnt mean better (with 7s launched 6 mths later than vs 7+)
so its just a no-brainer to get F5 (once its get cheaper)
if chiu dun chase after the "newest and betterest" cpu
Anyway
nice to see they decide to launch the X series earlier this yr
last yr they launch after CNY
PS: Hope this means the F6 series will launch "sooner rather than later" too
so that the F5 series can "faster" drop price
FloatingBarb
May I ask - X6 pro vs F5, whats the diff? X6 Pro chip is better but how about the cameras between the 2?
Also another consideration is the updates? Whats the diff between the 2 models?
chaiscool
cpu comparison F5 vs redmi K70E (poco x6 pro)
https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-7-plus-gen-2-vs-mediatek-dimensity-8300
Omg thought it was same chip as moi saw sd gen 2. Didn’t notice the +, aiyo sd marketing gotcha ah. Apparently got sd 7s gen2 and sd 7+ gen 2
walao …
wonder if the screen and camera will be better than f5, like higher ppi and res.
carboy00
if X6 Pro indeed is a rebranded Redmi K70E, it will have a higher resolution 1220p display and bigger battery 5500mAh. Cameras specs looks identical so not much diff.
China K70E has 90W wired charging but seems like X6 Pro will downgrade back to 67W.
Read HWZ Forum Rules on Poco F5 Pro
kkboy1
POCO X6 5G is coming - Jan 11
It says launching at 11 Jan
Shutterbox
I'll be in China next week
Considering to grab a note 12 turbo or (top up a bit) a k70e.
Both China rom of course.
chaiscool
Believe its one of those higher cost components, thus, with better cameras, don't think can fit into mid-range segment.
Basically eating into the margin.
Lower the cpu then. Every year update cpu but camera module reuse?? Iirc poco f3 to f5 same camera
chaiscool
Bulk purchase CPU, whereas made to order for camera module from Sony etc., thus, the reusing for multiple iterations?
Made to order for camera means need to reuse? Ain’t bulk purchase the one that got a lot leftover
froztheart
Perhaps CPU moves faster than camera modules. Most customers isn't gonna really have issues if the same camera modules are used for 2/3 iterations, as compared to having the same CPU.
Believe most can see that mobile devices technological advancements have plateau, nothing else much to add for every iterations.
I have no idea how they can keep up with yearly releases still.
