I read expensive etc. initially I thinking of trying the Alaska or Aeroair. The blades looks more deep and curve hence bring more windU installed in living room or bedroom? I just ordered 1 for study room, I think small enclosed area should be fine. I read reviews on Lazada and shopee, most reviews seems ok. My friends got fanco fans, they seems happy with it too. Same friend who got fanco and KDK, complained KDK no wind
What about the remote? Why RF no good?
No. Rather that is my own assessment. My initial impression is KDK is IR and fanco is RF. Apparently I am told all are RF? Another shop recommend Efenz. I use my eyes to see. Seems like those fan with light (especially those with exposed edges) will tends to cause this flickering effect on ceiling. The type where light is recess into the fan (example prestige and efenz) all don’t have these problem.Did they tell you why RF remote no good?
So seems like all no wind. HahaNo. Rather that is my own assessment. My initial impression is KDK is IR and fanco is RF. Apparently I am told all are RF? Another shop recommend Efenz. I use my eyes to see. Seems like those fan with light (especially those with exposed edges) will tends to cause this flickering effect on ceiling. The type where light is recess into the fan (example prestige and efenz) all don’t have these problem.
i understand only some models from Alaska has composite finishing like Haiku. The rest are all polymer blades. To me, the consideration is
(1) Safe
(2) Strong wind
(3) No flickering effect
I asked about KDK/ Spin and Haiku. They mentioned KDK/ Spin no wind, but spin looks very stylish. Haiku they mentioned L series (cost $700 per fan) got no wind. I series seems very expensive. They say if got too much money can buy. 2 of my rich friends using Haiku. They mentioned nothing to complaint but price ridiculously expensive. Haha
But got 4 years warranty although not sure about the customer service good or notToday morning I got nothing to do. Went to Jalan Besar and talk to some fan distributors. They say don’t buy fanco. Long term not reliable. Recommend Alaska, Aeroair, Pretige and Bestar
sometimes the windy effect is partially due to cooler temp by AC. Chance are wind will not feel as strong under normal fan usage which is when AC is off.Was at MEGA discount store today. The SA was pushing his best seller below claiming it performs better than the atas Haiku :
https://www.fanztec.com.sg/product/airstream/
The wind from his demo unit in store was indeed unbelievably strong even from a considerable distance away.
Yes. That's what I have observed for the ceiling fan lightings as well.No. Rather that is my own assessment. My initial impression is KDK is IR and fanco is RF. Apparently I am told all are RF? Another shop recommend Efenz. I use my eyes to see. Seems like those fan with light (especially those with exposed edges) will tends to cause this flickering effect on ceiling. The type where light is recess into the fan (example prestige and efenz) all don’t have these problem.
(1) Safe
(2) Strong wind
Yeah. I presume don’t have choice if eyes very sensitive. But u will sacrifice some brightness because if the side of lights are covered, then less brightYes. That's what I have observed for the ceiling fan lightings as well.
Ceiling fan lightings that has the side of the led light covered seems not to have flicking effect on ceiling as well. For example, Bestar, "Wind" model led lighting (side of the led light is covered) seems like don't have flicking problem.
tough ask dude, even KDK is MIC.Hi guys, any good fan to recommend with strong wind? noisy is not a problem.
Fanco good wind but why soo low reviews.
I saw many including Khind, Mistral, Alpha, Crestar ceiling fans but all look like China OEM, can tell from their remote its all same and can find them on Alibaba, hahaha.
Is KDK the only inhouse manufactured fan but its $400+.
I wonder if there is ceiling fan $200+ inhouse manufactured brand and not china oem.
Which model did you install?Just installed my fanco in my study room, so far so good. app works well too. quite windy at 3
