 Watch Ultra
Habrosus
First, congrats!
The Wifi is more like if you're just connected to your home Wifi but not to your phone and still being able to use it. I usually turn it off.
There's no use for Wifi when you're out. If you want to use it as a standalone device without connecting to your phone, you'll need to have a Numbershare plan. In other words, eSIM enabled.
To turn AOD on, go to your watch app, Display & Brightness, Always On to 'On'.
My Ultra is connected to phone (in turn connected to WiFi) at home, and it has Numbershare plan.
So, it doesn't matter if I choose to turn the Ultra WiFi off completely, right? :o
Snoweagle
Doesn’t matter. At home I’m connected the same way and my watch’s wifi is always off. But do remember wifi is automatically turned on once it’s too far away from your phone (BT disconnected).
Habrosus
BT can also be off? I've both on all this time, oh no! :s13:
On the watch BT it says:
Turning off BT disconnects Apple Watch from iPhone. Apple watch can use cellular data if it's enabled. Enabling cellular for extended periods uses more battery.
So...
If I want the watch to be connected 24/7 regardless if iPhone is near or far, which should be on/off? :o
I tend to walk out without the phone for short spans, so something should be turned on 24/7 without me having to remember to at the last minute for the watch's data to kick in?
I'm so confused...maybe that's why I've been having both on all this time 😅
Snoweagle
So...
The bottom line is when at home, watch's wifi no need to turn on, just connect via BT to your phone. The wifi is used only when your phone is turned off or out of range, and still able to send and receive data.
Habrosus
Gotcha! :grin:
Thank you 😊
Habrosus
Started using Wayfinder face (yup, at last) and dark mode didn't auto change this morning. Read that it happened after a firmware update.
Or am I the only one? :s34:
kashix
Hi anyone using nomad sports band for AWU/AWU2? How’s the quality? I saw Reddit say the connector a bit loose for ultra?
mikeeeey
the straps are boring...
currently using
trail
alpine
nike sports loop
tried titanium band - dont like
magnetic link - dont like
like not much to play around with
caesium2108
i have both volt & black, i think it fits nicely for mine.
currently using
trail
alpine
nike sports loop
agree! i feel like there should be nice straps that we have not tried yet. is there no better ones out there? Not sure if should get the ocean band since i bought mine with trail loop.. any opinions or suggestions?
galvin
Ocean band is the best for me. So good i got it in 2 colours.
Its waterproof and wont get smelly unlike the trail loop as i exercise daily. No need to worry about it getting stains from eating laksa!
The colour on my trail loop faded after i washed it with soap aiyo.
caesium2108
Do u have white? I think white is nice but not sure if easy to maintain.
galvin
Nope. Not an easy colour to maintain for sure.
My yellow ocean band already suffers from colour transfer from certain brands of jeans. It can be cleaned off though
kashix
I hooted 1 to try, should be coming tmr
dappercivility
I been tempted by the ultra since the day it was announced. Till now watch ultra 2 I still can't bear to spend the money to buy it 😅 it's really nice.
Habrosus
Before I bought my first Apple Watch AW7 45mm, I've never paid >$100 on a watch :s13: and yes, I then went on to buy an Ultra :grin:
