doratch
- Jul 24, 2017
No wor, for me I just use whitening toothpaste and mouth rinse to try the teeth white and clean. I am a heavy coffee drinker, so no matter what I do my teeth will be stained a bit.Veneers can definitely make the teeth super white and very artificial looking.
Dental veneers are custom-made shells that fit over the front surfaces of your teeth. They conceal cracks, chips, stains and other cosmetic imperfections. Veneers are one of the most common cosmetic dentistry treatments. There are several types of veneers available, depending on your specific goals.
If veneers are not fixed properly or mishandled/chipped off etc, your teeth might start to decay coz of bacteria, cavities etc and most of the time, it goes undetected. And by the time that you realised it, it might be too late.
