POCO X6 series
chaiscool
I gave up waiting for xiaomi and bought pixel 6a :)
How much you bought?
Perhaps CPU moves faster than camera modules. Most customers isn't gonna really have issues if the same camera modules are used for 2/3 iterations, as compared to having the same CPU.
Believe most can see that mobile devices technological advancements have plateau, nothing else much to add for every iterations.
I have no idea how they can keep up with yearly releases still.
Imo it’s the opposite. Average use for like social media / streaming no need so high end or yearly update cpu. Camera would be a more noticeable upgrade.
tian_yibang
Why so similar to f5? How about better camera instead ah. Midrange specs and pricing with top tier camera kym
Believe its one of those higher cost components, thus, with better cameras, don't think can fit into mid-range segment.
Basically eating into the margin.
Lower the cpu then. Every year update cpu but camera module reuse?? Iirc poco f3 to f5 same camera
Think the "better" camera will be fitted in F6/Pro
Standard pattern of XM/Poco or Tiong "cheap" fones in general la
they gib something, will cut down something (unless if its for their own domestic market which they "value" more)
Since this X6 series they alr market or selling-point as simi speed racing or supersonic hurricane hooha (which obviously focused on "performance" or for the gaming enthusiasts),
most likely they will gib something which lacks in X6 series for the upcumming F6 series
ie. moi personally hope they upgrade their cameras and audio (simi tuned by Harmon Kardon, JBL, AKG etc that kind) and if possible also upgrade the long time due USB 2.0 port to the latest so that it can sarpork DEX-mode like or display out thru MHL/HDMI in the F6
8K video, UD Fingerprint, 120W/200W fast charge etc all that nice-to-have but not essential imo
but moi do hope they retain/upgrade its wireless charging capabality tho
Krabs.
looks like the x6 pro can defeat F5 ? except lose headphone jack
finally they move ahead no more 6/126gb
DesilDesil
8/256 $279 global early bird price is $370~ SGD, but ours is $419 ?
I thought Singapore's inflation is only transitory
tian_yibang
This X6Pro obviously for "speed" performance
Anyway
think moi got mentioned before
that moving forward most if not all newer fones
will go for higher RAM and storage (since they want to obsolete-out sd card slot use and higher RAM is to futureproof demanding apps or games/workload for later)
ZrE0_Cha0s
seems like x6 both features pretty much the same stuff with only a few differences. SoC, battery. storage performance, color and base specs.
its like saying its a same phone with a few specs changes.
Shutterbox
this jap viewer rate this highly wor
maybe i go china buy the equivalent K70E, cheaper :D
Shutterbox
The POCO X6 and X6 Pro just launched with a couple of new features.
Let's go hands-on!
Full pricing details below.
💰 Pricing:
POCO X6 Pro 5G (8GB+256GB) RM1499
POCO X6 Pro 5G (12GB+512GB) RM1699
POCO X6 5G (8GB+256GB) RM1199
POCO X6 5G (12GB+256GB) RM1299
POCO X6 5G (12GB+512GB) RM1499
sango65
not sure why they ditch side mount fingerprint sensor. Isnt it troublesome to use screen fingerprint sensor especially you have to position your thumb exactly on the screen? Also, is the screen sensor faster / more reliable than side mount sensor?
Shutterbox
i have poco x3 nfc, x3 pro and a 13T
after a while i think the onscreen fingerpint is better, becos u get set it to unlock with either left or right hand fingers, from different directions.
side sensor has much limited contact area and angle, especially when you have case over your phone
