New forum: Bugs reporting list!
Dragon
Administrator
the error comes from clicking "insert quotes" button
It is working fine on my end. It may be due to your browser plugins or extensions. Please try with your browser in Incognito mode or using another browser. :unsure:
rizhal
Code:
<div class="tenor-gif-embed" data-postid="25407796" data-share-method="host" data-aspect-ratio="1.77778" data-width="100%"><a href="https://tenor.com/view/singapore-singapore-flag-gif-25407796">Singapore Singapore Flag GIF</a>from <a href="https://tenor.com/search/singapore-gifs">Singapore GIFs</a></div> <script type="text/javascript" async src="https://tenor.com/embed.js"></script>
szeli
twitter has transitioned to X and the new X urls are not embedding properly in posts
asymmetric
The edit text area got issue with my android keyboard must type many times for key to appear
Dragon
Administrator
We have not made any recent changes to the edit text function, could it be an issue with your mobile device or android keyboard settings? :unsure:
luei74
In mobile, today encounter not able to paste picture into above option, above option turn into grey now
reddevil0728
Are you using Adblock? You may not be seeing the ad above the sidebar, thus an empty space there.
Hope that this helps. :)
I do see the ad, so I get why the sidebar is half way down.
But I remb last time it will follow you all the way down.
currently even if you were to scroll all the way down, it’s still stuck just below the ad
Dragon
Administrator
That is strange, mine will scroll all the way down. Have you tried using another browser or browser incognito mode? :unsure:
Dragon
Administrator
Checked with our Tech team. The URL format appears to be different from what is supported by the forum software. It may be because Kaltura changed the format of their URLs and they have became unacceptable by the forum software.
We will update again when there is a fix to this issue. Thanks for spotting it. :)
paul02
Is it me or does signatures no longer show and peoples profile pictures are mostly blank now?
Dragon
Administrator
Some of our Moderators also encountered this recently while using certain browsers, ie brave, duckduckgo and opera. This is likely a browser issue as we did not make any change to our forum avatar settings. Please try using other browsers.
Thank you and have a good day. :)
Dragon
Administrator
Any idea how come my chrome browser normal mode cannot see my user profile and watch list but in Incognito mode can see? I cant even log out from my normal mode to see whether the issue still persist anot.
This is likely due to your browser addons, such as adblockers. Please try disabling your browser addons.
