Google Pixel 8 series
Do you think Google will give you a free Pixel Watch 2 if you preorder a Pixel 8 Pro?
  • Yes
    Votes: 24 21.1%
  • No
    Votes: 90 78.9%
  • Total voters
    114
  • Poll closed .
Loser
S24U calling out to you...
Your phone... Working seamlessly?
Loser
So far so good. dropped a few times still going strong. try uninstall the camera and reinstall again
I also tried that already... Uninstalled the updates and reinstall then restarted.
limmk
That's why different pixels have various issues. The same hardware may have different versions (like SSDs). software also significantly impacts the overall experience
Loser
You mean smartphone lottery within the same model/production line?
Means Google's QC not that good also. Also means I lost 2 smartphone lottery in a row with S23U and pixel 8 pro. :frown:
Previously all the onepluses and Pixel 7 pro no issues.
Lazyfoolz
Well since google moved their production out to India already. QC as expected liao
Tbh OnePlus still one of the best out there but lot of battery's draining issue for my OnePlus Ace Pro. Probably gonna wait for the Ace 3 for the Genshin version.
Now when i need to think twice now. A P8P or OnePlus Ace 3 👀
justln
No help, restarted multiple times.
Even tried to reboot into safe mode and launch camera app then restart into normal mode like someone suggested online also same. In safe mode the shutter also lags when continuously triggered.
I really don't want to factory reset sia very leceh. :frown:
My camera app got very bad shutter speed, startup very blurry, need to wait 3-4 seconds or shake the phone to focus.
I uninstalled the updates, clear cache and data, disable/enable camera app, restart phone, reinstall camera updates. Now ok liao.
If not, I see pple say is hardware issue, RMA get another set, no issues.
Loser
Bro can link me the source saying it's hardware issue?
Singapore RMA very difficult one, unless send the phone in to CDTI for them to check and then still no guarantees can replace also... :frown:
justln
Will they give you a new set to use first before you need to return the faulty set?
HMAN
When you expand it, it says 'wifi 6' :s13: :rolleyes:
Is this screen shot of Singapore local set.
I have the 6E router with 6GHz band but Pixel 8pro never detect the 6Hz band even I purposely turn on 6GHz band.
Indeed most bands support were decided before mass production, any post release bands update will hardly be entertained.
limmk
Yes local set
