maple_mak
- Nov 5, 2020
anyone use this brand of case before?
Too bad no local distributor selling the brand here
this kind 3mm case.. TB a lot mah...Too bad no local distributor selling the brand here![]()
Got any new leak lolsorry nope. cuz I don't use privacy. I only surf AV on android.
torras used to be my fav sp. but their 15 series will lift at the edges.Is lifting around the edges of tempered glass screen protector to be expected?
I ordered 2 different tempered glass protector recently, a cheapo <$1 one from aliexpress and noticed that the entire edge of the screen protector is lifted due to the rounded screen.
then i ordered from from Torras which seems well received and noticed that the edge of the glass is lifted as well. I followed the instructions and used the plastic orange rig to sit the screen protector.
Can try Okonz privacy screen protector on shopee. Used that and seems ok.Yup, no black border.
Will look out for screen protectors with black border next time... Any recommendations for a quality privacy screen protector?
Smart devil 360 privacy is good but but but it scratches very very easily. I put my AirPods in pocket together with phone will scratch the screen protectorYup, no black border.
what is the damage?
$30++what is the damage?
https://www.moft.us/products/iphone-leather-case-magsafe-compatible?variant=40245032845399Hey all, getting a iphone 15plus this thurs so looking at casings now.
Wanted to get the magsafe leather case from Moft but seems that they do not have case for iphone 15 plus.
Are they any good alternatives for leather magsafe case?
I'm currently using Apple Leather Case for my Iphone 13 but seems that Apple also does not have leather case anymore.
Thanks!
ahhh.... my 1st case.
What case are you currently using now.ahhh.... my 1st case.
less than $10 TB leather case with no MagSafe nia...What case are you currently using now.
I still tend to like the sheath.
Using the movas vegan too. Great so far. Better than the silly sheath which was my first caseThis Moft Movas vegan leather casing is not bad. I quite like it. Maybe a few months later then i order the Aulumu one.
I also dun need MagSafeless than $10 TB leather case with no MagSafe nia...
