Isit worth the upgrade to x100p ? Or wait for magic6pro global?anyone need M5p accessories let me know?
I bought some before i bought the phone, in the end went for X100P.. hehe..
https://carousell.app.link/jknoBhgvAGb
Help me clear.. negotiable for self collect!
i like the x100p.. but wondering if the sd8g3 will be faster.. lolIsit worth the upgrade to x100p ? Or wait for magic6pro global?
unlikely. samsung is samsung, google is google, honor is honor.can i check if the data/appointment in samsung calendar can be transferred/port over to honor magic5 pro calendar?
I have try factory reset my phone but same problem.Anyone experienced NFC Google pay issue after latest update 7.1.0.197 ?
Phone updated to this update last night. This morning board the bus was working fine. When alighting the bus, hit error saying software does not meet Google pay standard.
Then try again at MRT gantry also same error. Restart phone also did not solve the issue
i have no issues.. maybe u wanna try to clear google play services cache and see if it worksI have try factory reset my phone but same problem.
Just try to use Mac Donald App with similar error. Security check failed. Please check and run trusted Google OS.
Anyone encounter similar issue after latest update to 7.1.0.197 ?
Didn't works. I try clear data as well.i have no issues.. maybe u wanna try to clear google play services cache and see if it works
You also have the same issue whereby unable to use Google Pay NFC / Mac Donald app ?Having same issue, any luck with reinstating firmware version?
Yea also same thing due to the latest update, but my corporate apps (outlook, teams) are still working, so don't know if it's an Honor problem or Google pay problem.You also have the same issue whereby unable to use Google Pay NFC / Mac Donald app ?
I went down service centre over the weekend. They have try to install earlier version/batch but still unable to resolve.
Did another reinstall without batch 3 update (left it pending) also unable to work.
I believe is honor security patch issue with google. When I factory reset my phone earlier before going to service centre, Mac Donald app also unable to setup successfully. It mention Google OS not trusted.Yea also same thing due to the latest update, but my corporate apps (outlook, teams) are still working, so don't know if it's an Honor problem or Google pay problem.
My Mcdonald app is able to be used if I don't pay by Google pay and instead just keying in the cc details directly, so it's still workable for meI believe is honor security patch issue with google. When I factory reset my phone earlier before going to service centre, Mac Donald app also unable to setup successfully. It mention Google OS not trusted.
The last time I see same error was using Huawei phone and sideload Mac Donald app as it require a valid Google play store.
Thanks. I just try download MacDonald app and able to setup successfully. No more OS security error.Today Google pay is mysteriously working fine again without any Honor or Google patches
I using MY set, still no VoLTE for giga.Anyone can confirm giga! got VoLTE? As not sure MY or SG set got different or not.
