Fastest ISP?
seowbin
Everyone and anyone can claim they are fastest...
fastest can be highest bandwidth during speedtest with their own server :s13:
or to me, fastest means lowest latency to destination
Just discovered this website (pretty much china focus but test the rest of the world as well)
Come test and show us your result - https://tools.ipip.net/newping.php
Here's moi result based on my home router IP
seowbin
eh you running a home datacentre is it 🤣
Anyway, how you setup your home connection? You establish a VPN tunnel to your colo?
Traffic goes via GPON to moi DC directly lor. Moi ISP wannabe ma so if release to public eventually, all have the same experience
seowbin
I think MR have 2 different type of routing table for normal and gamer plan so worth testing both .Same for viewqwest? To be fair to them.
Sinktel I won't say good looking at the global average result. :s13: people average is 150+
Sinktel is 200+ms
Sinktel is 200+ms
Just looking at the picture and ignore the texts on the right. :)
Singtel to China is good. :s13:
seowbin
Sinktel to CU ish good. I also using them to get there
Just like most, to CT ish ....
Essentially, this thread can answer those who complain taobao slow, china ęŠ–éŸ³ slow cannot load kind of thing :s13: they know who to avoid if they need such content
Now missing starhub , simba, whizcomms
And those with 2 routing tables
vq and mr ( those with gamer or normal plan) . Those who posted earlier, maybe can indicate the type of plan you are on
Here is my other homenetwork using OpenWRT, Singtel 1Gbps plan.
The China results are almost comparable to the above result if we just look at the colours.
Two worse results: HeiLongJIang and Taiwan
One better result: SiChuan.
Yes it can answer the question from VQ users. But strangely I do not see complaints from M1 users.
MR to China probably improved a lot after being acquired by Starhub. There used to be complaints as well.
seowbin
i believe certain subnets are connected to CT via their new CU link
i just done a traceroute via ripe altas. Some super fast, mostly slow. This lead me to believe those fast one are on gamer plan while the rest are on cheaper plan ... (it can be reverse but doesn't make sense :s13: )
viewqwest all above >200ms, nothing to discuss :p
seowbin
maybe they are connected to some cdn, that's why no complain or they suck it up because cheap doesn't means good :s34:
Here's M1 to CT result.
