PC freeze without bsod
Informant
Specs as below:
Ryzen 5 5600x
silverstone va 650w psu gold
rtx 3050
corsair 16gb ram
asus b550m-a wifi ii
1tb samsung ssd
1tb wd hdd
this pc was purchase from mansa on september 2022. symptom start way back early March 2023, every single month will freeze 1 time for literally no reason. pc start up around 3-5min will freeze already. between march 2023 ~ september 2023. Mansa change each every component inclusive of psu & mobo plus clean windows installation. the freezing issues still occurs. october 2023 then change the RAM. surprisingly the freeze issue resolved.
now jan this year the freezing issue came back again. this time round is every 1.5 week freeze once while on idle (e.g have a 30min lunch/dinner).
can any expert let me know whats the possible root causes of pc freeze? or anyway to trigger a bsod for easier identifying the root cause of pc freeze??????
mouse(cursor still can move. cannot click anything) and keyboard(numlock still can toggle) still working when it freeze. replug again then no led light already.
my usages is pretty mild, youtube & some light gaming with android emulator only.
Informant
Checked, no integrity violation was found. what alternative way can i find the root causes?
liewhl
Specs as below:
Ryzen 5 5600x
rtx 3050
corsair 16gb ram
1tb samsung ssd
1tb wd hdd
can any expert let me know whats the possible root causes of pc freeze? or anyway to trigger a bsod for easier identifying the root cause of pc freeze?????? mouse and keyboard still working when it freeze. replug again then no led light already.
Freeze can be alot of thing but normally the main suspect I think is psu. You can try to download some gpu/cpu and psu stress test software and try to run your pc with it at full load for 15-30 min. If it is really serious, normally it will just freeze within min.
One good software is OCCT
However, your pc part is still quite new, I think you still can rma them. You can try to send in your main component to rma like cpu, motherboard and psu if you are free
Informant
I contact the vendors they change the PSU before. so it's likely psu again? OCCT will cover psu stress test also? Can let me know whats the set up for OCCT? or just run by default can already
liewhl
Normally, a faulty psu with unstable power output will freeze the computer randomly is the main suspect. However, a faulty cpu, GPU and motherboard can also lead to this but they are less likely
Yes, it will cover psu, GPU and cpu stress test.
There different option on the tool with label. You click on the the type of test you want. Like full stress test or psu stress test or other part stress test
Basically in default setting, you are just running your components at 100% load so the default will be fine
TanKianW
Specs as below:
Ryzen 5 5600x
rtx 3050
corsair 16gb ram
1tb samsung ssd
1tb wd hdd
1) To check the blue screen of death (BSOD) error message on Windows, you can use the Event Viewer:​
  1. Open the Event Viewer​
  2. Click Action > Create Custom View​
  3. Change the "Logged" timeframe to include the time when you saw the error​
  4. Check the "Error" box​
  5. Change Event Logs to "Windows Logs" and click OK​
  6. Enter a name for your view and select OK​
  7. Click each logged error to view its details
You can also view the BSOD logs by going to Event Viewer, expanding Windows Logs, and selecting System. Look for events labeled “BugCheck” to find information about the blue screen error.
2) To make a Blue Screen of Death (BSOD) stay on the screen, you can do the following:​
  1. Click the Settings button under Startup and Recovery​
  2. Clear the checkbox for Automatically restart​
  3. Click OK and close any remaining windows
After this, the BSOD will remain on the screen until you manually restart the computer.​
Informant
The problem is. it just remain frozen permanently. won't trigger a bsod.
Phen8210
Ask Mansa for a refund if they can't solve the problem.
This kind of issue is hard to tell without troubleshooting in person.
This is an example of why prebuilds aren't at all fuss-free, especially when such tricky issues arise and need to be troubleshot.
86technie
1) Is AMD chipset driver installed?
I know some repairman when they do Windows installation.
Driver install from Win update may cause issue.
I never use Win update to install driver
2) Which model is that Ram, certain Corsair ram are optimized for AMD.
You can use CPU-Z to check the ram model.
I suspect these two if not is Windows never configure properly.
TanKianW
Regardless of whether it trigger a BSOD, check the event viewer for critical error message that has been logged.
If the error message is logged, it is easier to pinpoint which component causing the problem with a Google search.
Informant
For linpack test i kena bsod one time after 5min. Subsequently reduce the memory to 8192mb then 16384mb again no bsod. the rest ok. Accurate anot?
Settings below.
Error below for details
1. How to tell whether my amd chipset driver is installed from windows or amd itself?
2.
Corsair RGB Vengeance Pro SL
Informant
Not just BSOD. Check the event viewer for critical error message that has been logged.
i dont see any abnormality so far 12midnight is the one causing pc frozen then i force restart. 9.38am one is occt tools to trigger bsod. 10:59am one never trigger bsod when testing via occt tool.
86technie
Settings below.
2.
Ram is correct, under program and features.
You can use the taskbar search.
See if you can see a AMD chipset.
tigerwoods
Specs as below:
Ryzen 5 5600x
rtx 3050
corsair 16gb ram
1tb samsung ssd
1tb wd hdd
do a memory test
Informant
so how now? this monthly freezing issues damn tricky leh.. Mansa change the whole component for me between march 2023 ~ september 2023 & ram on october 2023..
Phen8210
I usually filter like that to check
Use this as an example.
Look at the timestamp of when the 'critical occurred', which is kernel power, because when you improper shutdown you surely will trigger that.
Next, look for the timestamps (highlighted in green) that are the same as when the critical appeared. On the right side, you can see the events that are causing the PC to crash are the same and have repeated itself (both highlighted sections).
Informant
Can your system survive 15 min of cpu or psu stress test?
15min stress test no issue. except the linpack 16384mb cause bsod. subsequent check again on 8192mb & 16384mb no bsod. morning check liao
Informant
This only trigger by force restart through power button when comp freeze.
