Phen8210
- Jul 29, 2011
This only trigger when comp freeze.
Filter to see critical and error together
Possible ram issue again? 4 month old only leh. somemore is BNIB de i personally go down to their warehouse to see them change. That time before the RAM change they also cannot figure out the root cause with all the stress test for 1 week. then they change all the exact component. I personally cannot close 1 eye for monthly freezing issue. Later i got important project never save then suddenly freeze. which it's not a good idea..if you suspect your ram might be the issue, another way is to just run 1 stick at a time and observe if the freeze still occur
actually if your issue is ezily reproduce, just take it down and show it to them else just take a video or show then the syslog, i think is their problem instead of your.Possible ram issue again? 4 month old only leh. somemore is BNIB de i personally go down to their warehouse to see them change. That time before the RAM change they also cannot figure out the root cause with all the stress test for 1 week. then they change all the exact component. I personally cannot close 1 eye for monthly freezing issue. Later i got important project never save then suddenly freeze. which it's not a good idea..
This issue occurs when i go lunch or dinner in idle mode around 15-20min idle
Most recent, 12midnight 3 Feb
Previous recent freeze 21 Jan
Last 2 recent before RAM changes, This issue occurs when computer start up for 3-5min.
Sep 2023
Aug 2023
I will try a few things.
Update BIOS & also disable FTPM on Bios (if using win 10)
Fresh reinstall GPU drivers using DDU & also AMD Chipset
When you mention they re-install Windows, did they really reinstall it fresh, or did they push a saved image?
Also, how are your temperatures?
normally got 3 years warranty like AftershockDon't understand is my problem or the component they build for me is just unlucky sia..
Sep 2022 Buy (No issue for 6 month till March 2023)
Mar 2023 - Oct 2023 (Intermittent issue occurs in between)
Oct 2023 - Jan 2024 (No issue for 3 month till Late Jan 2024)
Jan 2024 - Present.
Why the lifespan so short de......
Jan 2024 - Present.
Is not tricky, I don't want to share too much if not later mod/admin give me points.![]()
so how now? this monthly freezing issues damn tricky leh.. Mansa change the whole component for me between march 2023 ~ september 2023 & ram on october 2023..
Jan 2024 - Present.
Your CPU might be faulty, best to RMA. If you do not want to dismantle your build then go with this.Does it freeze at idle or when there are activities (gaming, etc)? If yes, disable CPU c-state, so your CPU power won't drop too low. Usually, if there is a hardware error BSOD should appear. See if that helps.
Your ram is not running at it's rated speed, should be running at 3200mhz. Overclocked ram are designed to run stable at higher voltage. Go to your bios set ram to XMP to run at 3200mhz and manually fix the ram voltage to 1.35v.For linpack test i kena bsod one time after 5min. Subsequently reduce the memory to 8192mb then 16384mb again no bsod. the rest ok. Accurate anot?
Settings below.
Error below for details
1. How to tell whether my amd chipset driver is installed from windows or amd itself?
2.
Corsair RGB Vengeance Pro SL
