for Cyberpunk 2077 HDR cyberpunk experience
i would suggest to redo HDR calibration because sometime different GPU and everything reset on monitor due to driver changes.Yongkit, do you need to redo your HDR Calibration if you change GPU but use same monitor?
for I redo calibration everytime i change cable, I am now using the elecom HDMI 2.1 8k cable:
from my reseach on reddit, some mentioned they have some inconsistency with 4000 series gpu on this monitor, may i know if your unit so far ok?
how it goes when u use that 2.1 8k hdmi cablei would suggest to redo HDR calibration because sometime different GPU and everything reset on monitor due to driver changes.
Wow very niceSo far everything works fine and smooth. Hdr looks same as my 3080 Ti. Temps and all are good too. Only Jedi Survivor seems to have weird hotspot spike 6 degrees higher than normal at loading menu then become normal once the game starts. Stupid game at optimising game files at menu creates unnecessary GPU load spikes. But very happy with my 4090 TUF non-OC version. Even with 1.07V, I can hit 3045Mhz easy. Nvidia gimped all new AD102-301 Dies to 1.07v. Early batch with AD102-300 were all 1.1V. Anyway got new nvflash which has been hacked to allow 1.07v Dies to flash to 1.1v. Will try it at some point. Best thing is my unit has ZERO coil whine. Not even a faint coil whine when running 550W+ loads.
i finally tried it through game pass, play until got the cutter then i very scare to continue, very scary but HDR is very nice true blackPlayed some Dead Space at night on my AW3423DW. Absolutely amazing game that showcases HDR can elevate your gaming experience.
Not so bad la. There are some decent games on the platform. For example, I started playing Controls on it a couple of years back. However, I am unsure if it is worth the current monthly subscription. In most cases, I will use Game Pass to try some games, and buy them if they are on sale. Buying a discounted full game on Steam is even cheaper than 1 month subscription of Game Pass in most cases.that's why its called game pass, it has all the games you should pass![]()
Many thanks, for now I use only in game native HDR and auto HDR. No plan to use mod. Maybe others are more willing to try@Yongkit and all HDR fans, i found this tool NvTrueHDR that enable RTX HDR for games and video.
Get it here > https://www.nexusmods.com/site/mods/781 and share your experiences.
