Japan sim card?
AppleTree17
If need to make urgent calls, eg call airbnb, home etc where there is no wifi, what’s the best way to call? Thank you for sharing your advice,
cpuer
Line is popular there, can install it just in case.
kenapa siol
Cant seem to get my esim working. Do we turn ON both primary and esim? Or turn OFF my primary? Chosen softbank for airalo or kddi, cant get a connection.
saffronsatire
Recently spouse use another brand of e-sim, recall instruction need to turn off primary
cpuer
bottom line is data should be on on esim and set for roaming, primary should be on for voice, sms etc
rrr2015
depends on your mobile, some can support dual SIM active some can't. if doesn't work, move voice+data over to eSIM & disable physical SIM
kenapa siol
Ok meaning if i dont need voice call and sms, i should turn off my primary line and on the esim only. But if i need these, i will be charge with my telco roaming if i receive any sms/voice call?
Can liao after i reset my phone. Heng ah..
Now im monitoring my starhub app to see if any theres any sudden usage of data here despite turning off my pri line.
zoossh
Can you speak Japanese?
Can’t but wonder if I can learn enough to book a reservation for restaurants…
a recent trip I find that many places either requires reservation or is full house when I arrive.
cpuer
i keep primary on for voice and sms as i sometimes gets otp. if you don't have this need or wants to turn on as and when required, you can off the primary.
