- Aug 8, 2012
No, only for tourist prepaid, eSIM is available.Does SingTel have eSIM now?
Surprisingly, SingTel has MVNO supporting eSIM (Vivifi) but StarHub doesn't. Not really counting MR since it's only for 5GThis has been there for a while, since MyRepublic's 5G eSIM is already using Starhub's infra.
Just a matter of time before it will be released, my guess will be probably by next iPhone release.
Singtel likely to be the slowest though they also do provide eSIM on prepaid for tourist SIM,
Starhub is supporting eSIM too but only for their prepaid currently.Surprisingly, SingTel has MVNO supporting eSIM (Vivifi) but StarHub doesn't. Not really counting MR since it's only for 5G
https://www.starhub.com/personal/mobile/mobile-phones-plans/prepaid-cards/travel-sim.html
Yes, currently only for tourist as per link that I provided.
Interesting that they would sell this through their StarHub app and not the StarHub Prepaid app like SingTel does.Starhub is supporting eSIM too but only for their prepaid currently.
Its wiser to consolidate to one main app for simplicity sake imo, no point maintaining 2 seperate apps.Interesting that they would sell this through their StarHub app and not the StarHub Prepaid app like SingTel does.
Generally I agree, but in this case, unless StarHub absorbs the current prepaid app into the main app, it doesn’t really make sense?Its wiser to consolidate to one main app for simplicity sake imo, no point maintaining 2 seperate apps.
But oh well, typical SG way of running systems.
Perhaps Starhub might be slowly consolidating into a single app.Generally I agree, but in this case, unless StarHub absorbs the current prepaid app into the main app, it doesn’t really make sense?
I have a prepaid plan with StarHub, wonder if I can sign up for this Tourist plan and then port that number over, just so I can have eSIM functionalityYes, currently only for tourist as per link that I provided.
Suggest to check first before porting out and back in.I have a prepaid plan with StarHub, wonder if I can sign up for this Tourist plan and then port that number over, just so I can have eSIM functionality![]()
Porting prepaid numbers across carriers is almost impossible from my understanding but within the same carrier, might be different.Suggest to check first before porting out and back in.
Doubt you can directly port in since you are currently w SH.
You can actually port among the telcos but its more of a manual process I believe.Porting prepaid numbers across carriers is almost impossible from my understanding but within the same carrier, might be different.
Sadly, it’s so new, I doubt StarHub agents are too familiar with it.
When Singtel first launched eSIM for prepaid, they ended up just giving refunds to failed activations instead of trying to troubleshoot in-depth
StarHub also got eSim for prepaid......M1, Singtel have had tourist e-sims for a while already. Can we port into tourist sim? Anyone done it before?
Volte implementation for esim seems patchy and inconsistent just like volte used to be inconsistent too.Just switched to eSIM on my existing Circles plan, now I am not seeing VoLTE and hardly getting 5G, previously on physical SIM it was fine for both. Using Xiaomi 13T Pro, anyone with similar issues?
Read HWZ Forum Rules on Xiaomi 13T Pro
starhub happy has esims? link please.StarHub also got eSim for prepaid......
Which means the rest of Singtel and its MVNO should all be starting soon.GOMO added support for eSIM on 18 Mar.
https://gomo.sg/esim
