Shopee selling around S$27. Diff is quality. Few cents type might be using plastic so you might get blurry results.30usd for camera lens, How do those differ from the few cents type from Shopee?
y crumpled? plastic sheet? what's the weight?
huh what crumpled? it's the old hard plastic sheet package. i not able to measurey crumpled? plastic sheet? what's the weight?
This?Hi guys.
i remember someone shared a website that helps to align a screen protector at its edges. Does anyone knows what url is it ? Many thanks.
WOW! Forged Carbon! Didnt know UAG made a Forged Carbon variant! Is the action button covered or still open type?
the button is covered for this versionWOW! Forged Carbon! Didnt know UAG made a Forged Carbon variant! Is the action button covered or still open type?
ahh yes yes. Thank you!
Can you share photos of the case installed on your phone? How much and where did you order it?
sorry i no other cameraCan you share photos of the case installed on your phone? How much and where did you order it?
If on budget, consider Ugreen Clear caseHi, anyone can help recommend a transparent hard casing for iphone 15 pro max?
Ugreen clear case is cheap and good. Covers the whole thing Including the camera area got MagSafe magnet on It. Can get for less than $10 during sales period.Hi, anyone can help recommend a transparent hard casing for iphone 15 pro max?
