MyRepublic Mobile discussion thread
badboi_kh
Sadly, looks like classic case of you pay for what you get. TBH i was considering MR 5G or Singtel. Price wise no brainer lah. $24.95 for 6 months then $29.95. No contract, free caller ID & 7GB data daily so 210GB a month.
Singtel first 12 months still ok just a bit more ex than MR but after that siong sia. $51.30 a month ($45.85 + caller ID $5.45) & data from 188GB reduce to only 50GB a month. And tied down for another 12 months.
Pricewise Singtel really not worth it after 12 months. But if their 5G coverage is the best, then i guess they can afford to be arrogant when pricing.
yeah im abit caught i thoguht backed by starhub should be safe.. but seemingly as telco sell wholesale to mvno, its still not as good as the telco itself..
singtel is really ex tho, im considering zym now.. backed by singtel..
crystalnox
zym isn't backed by Singtel, they just purchase data wholesale from singtel and resell it. Same as vivifi, Zero1, CMLink, etc.
Singrish
Understandable that telco will not let MVNO have full benefits else they sabo ownself. Have decided to go with Singtel. Fingers crossed!
ST9611
he was referring to receiving incoming roaming calls via data using MyRepublic app which is free…
How is the free incoming roaming voice calls in JB using the app?
Guess need to do something else the calls will be charged too.
gaoqikai
Hi all, do any of you have experience porting out of MyRepublic 5G? to SIMBA
I actually did once in May 2023. That time I chose "MyRepublic Mobile" at SIMBA site when indicating prev telco. Everything works.
This time I also put "MyRepublic Mobile". But port in failed, SIMBA says MR did not release my number.
I asked MR and they say should put "StarHub" instead. I find that confusing?
So did anyone share same experience? Thx
froztheart
Yup, as MR 5G is under Starhub, just resubmit and port in again as what MR advised.
gaoqikai
Thank you, I have requested to do so.
It's a bit weird, because all virtual operators' names are listed their, like giga, MR, ZYM, ...
In this case not suer to input virtual operator's name or the back-bone operator's
froztheart
If MVNO is available, select MVNO, otherwise, backbone infra. :)
alvino
Hey guys, just applied for 5G plan this morning for port in from Vivifi.
Few questions
1. Sign the plan today Friday morning, will I get ported in by sat or Monday?
2. If I slipped into area without 5G will I be using 4G from m1’s coverage instead? APN got problem?
Pre thanks for any helpful replies
alvino
no, if you got the 5G plan, the 4G network is using starhub 4G.
Only 4G plan use M1
Thanks got it!
Just for other fellow users' future reference.
esim new order applied on friday morning(with port in request), still got ported in on saturday. i was worrying its considered non working day!
About 850mbps down for the 5G SA. not bad not bad!
carboy00
Hi anyone on MR 5G plan using eSIM on Xiaomi 13T / 13T Pro or any Xiaomi phones? Any issues with VoLTE?
dantom04
anyone using MR 5G on pixel phone? esim. cos i encounter this issue of once i connected to 5G , im unable to make any in and out calls and they jus told me network unavailable. previously on CL esim no such issue.
anyone still encounter this issue on pixel hp with eSIM?
wirelesslink
how long did it take for 'My Number' to appear correctly for iPhone port in users using eSIM? Unable to activate imessage as a result, still the same after staff offered esim replacement
froztheart
anyone at comex able to share the deals for myr mobile? :)
