- Sep 16, 2018
Graphing DNS resolution has a lot of factors which could influence the outcome... Not only are you testing the latency of your connection to the DNS resolver, but also the latency of the connection from the DNS resolver to the authoritative DNS server of the hostname you are querying, plus the authoritative DNS servers in the entire hierarchy from the root all the way up to the actual hostname.
Then you have the added randomness of wether the host you query and/or any of the hierarchy queries are already present in the cache or not.
I was running smokeping for a while but later decided not to run it. Right now my PVE machine has only one instance of pfSense running, and another LXC container for simple Linux networking utilities. My Asus RT-AX82U router has also the facitlity (EntWare) to run many Linux network utilities.
Just wondering what will be a simple command to be similar to the smokeping dns probe. I was thinking about nslookup or dig. But there seems to be a difference.
