- Sep 16, 2018
The point I was trying to make is that SQM/QoS measures are not so useful for wireless clients when the signal is weak. The more important thing when the signal is weak is to add extra AP (if there is LAN port near by) or repeater (not as effective as AP).
SQM/QoS will still be useful if the CPU can handle the task without sacrificing much on line rate. Typical consumer grade wireless router can not handle 1Gbps SQM/QoS effectively. That is why when people only gets 300Mbps or 600Mbps from wired connection from their Asus routers, the first thing is to check whether they have turn QoS Feature ON or not. But if use a router with powerful CPU, like using OpenWRT on an Intel N100 CPU based mini PC, then there should be no issues using SQM/QoS.
There could also be effective SQM/QoS implementations which does not tax the consumer router CPU so much but I do not know which are the better ones for consumer routers.
For those who want to ask about mesh with Ethernet Backhaul or Wireless Backhaul.
1) Mesh with Ethernet Backhaul --> glorified AP with some roaming helping technologies, like 802.11 k/v/r or EasyMesh or proprietory technology like Asus AImesh, Netgear Orbi, TP-Link Deco and Linksys Velop. Small Enterprise and Enterprise Grade APs may have even better technology to help roaming.
2) Mesh with Wireless Backhaul --> glorified repeater with some roaming helping technologies, like 802.11 k/v/r or EasyMesh or proprietory technology like Asus AImesh, Netgear Orbi, TP-Link Deco and Linksys Velop. Small Enterprise and Enterprise Grade APs may have even better technology to help roaming.
