TP-Link EB810v - Quick overview
trenzterra
Posting here to consolidate information about the TP-Link EB810v which is currently being provided by StarHub for their 10Gbps plans and sharing my experience.
First off, the default password to login is Starhub@123 in case the trooper forgot to give you the password.
I am running it in a mesh configuration (paying extra $15/mth for 24 months for the extra set), with one set in my DB box and one set in my middle bedroom. I am getting full coverage throughout my 4 room BTO, although 5GHz speeds generally seem slightly better than 6GHz. Testing using my phone (Wi-Fi 6E, S23 Ultra), I am getting about 1.4Gbps speeds if I am relatively near the router, or about 800-900Mbps if I am further away. It's pretty much gigabit LAN speeds, so nothing to complain about here.
The size of the router is gigantic. Together with the ONT, there is barely any space left in the DB Box. It also gets rather warm and suggest that you hook up a laptop cooler or something to the USB port on the router.
In terms of port selection, the EB810v is better than the BE805 and HB810. Apart from the 10Gbps LAN and WAN ports, you get three 2.5Gbps ports. This is compared to 4x1Gbps + 1x10Gbps on the BE805 and only 2x2.5Gbps + 1x10Gbps on the HB810.
Web interface wise, you can set up the router in "router" or "access point" mode, or as an EasyMesh node.
You can set VLAN settings although I have not tried it. Setting custom DNS for both IPv4 and IPv6 is possible.
There is support for TP-Link, Dyndns and No-IP dynamic DNS, but I have not tried either.
By default, there is "band steering" enabled where 2.4GHz and 5GHz can share one SSID. So far it seems to work fine for me, my 5GHz devices always connect at 5GHz. 6GHz is always on a separate band unless you enable MLO, although I do not experience much issue having 6GHz sharing the same SSID as 2.4GHz & 5GHz. In my experience, using MLO on a non-MLO device results in the device connecting to the 2.4GHz band, resulting in poor performance.
Port forwarding, DMZ, UPnP, port triggering and static DHCP are featured.
Guest networks are also supported, and they are placed on a separate subnet from your main SSIDs and therefore cannot access your main devices (a minor shortcoming vs ASUS which allow you to disable that option, although TP-Link also has a separate Multi SSID function which serves a similar purpose I guess). The guest networks also work over the mesh -- I can see devices connected to either the main router or the mesh node. The only shortcoming is that when you have band steering enabled, the setting also transfers to the guest network. Hence, there is no way to have a 2.4GHz-only guest network if you have band steering enabled, so certain IoT devices may have compatibility issues on initial pairing.
There are two other notable shortcomings I noticed compared to my previous AX86U + XD5 set up. One is that I cannot bind a specific device to a particular mesh node. However, this still seems ok for me as my devices generally connect to the closest node (I had an issue previously with my AiMesh setup where a device close to my main router would instead connect to my XD5 further away instead). Also, there is no ability to define the SNR limit at which your device is forced to change nodes, which could mean that your device would linger on one specific node even though it has poor connection. But so far in my small flat, haven't really experienced such issues and generally getting 5 bars throughout.
Apparatus
Just to add
The 10G SFP+ WAN (Combo) port cannot be used. Only can use the 10GE WAN(Combo)/LAN ports
Does not come with built-in speedtest
alex22
Just to add
You plugged in a module and it wasn't accessible?
Apparatus
Starhub seems to have the most comprehensive info on TP-Link EB810v.
https://www.starhub.com/personal/support/article.html?id=kD5GRQtfxB3LxaEDMjuFm5
TP-Link itself has very limited info.
https://www.tp-link.com/sg/service-provider/wifi-router/eb810v/
Some useful info from Starhub with regard to mesh node.
1) How does the TP-Link EB810v mesh work?
The TP-Link EB810v uses Easymesh* technology and is compatible with another TP-Link EB810v. For best performance and compatibility, we recommend meshing with another EB810v.
*Mesh nodes that are available from other brands would not be compatible with the TP-Link EB810V. We strongly recommend using another TP-Link EB810v for best performance.​
2) I need more coverage on my home network with the TP-Link EB810v, what can I do?
You can extend the coverage by purchasing another TP-Link EB810v. The 2nd unit can be purchased at $15 per month (for 24 months) from StarHub.​
3) Why do I have so many MLO SSIDs? (In a mesh of EB810v(s))
Every router has its own SSID for MLO operations and this is normal. It is to ensure that when a compatible MLO device is connected to the MLO network, MLO operations can perform its best to aggregate multiple links without interfering with traditional band steering (2.4Ghz and 5Ghz combined) or standalone 2.4Ghz, 5Ghz and 6Ghz networks.
4) Can the mesh node’s MLO SSID be changed?
Currently, this cannot be changed.​
kimsix
Here is more detailed review of brother be800, seems to use IPQ9570 and not IPQ9574. I think the different is 4 variant have onboard 2.4ghz wireless for some reason
Indeed looks that 2.4GHz wireless integration seems to be the differences between IPQ9574 and IPQ9570. Same for IPQ9554 and IPQ9550.
Ref:
http://www.bitswrt.com/wifi7
More info about WiFI SOCs from Qualcomm
https://wikidevi.wi-cat.ru/Qualcomm
Known devices to use Qualcomm WiFi 7 SOCs. Take note Asus uses Broadcom BCM4916 (quad-core Arm Cortex A53 at 2.6GHz) in their WiFi 7 routers as of now. IPQ9574/9570/9554/9550 should be faster than BCM4916.
High end
IPQ9754 -- Xiaomi BE10000, H3C Magic BE18000 (quad-core Arm Cortex A73 at 2.2GHz)
Mid-High end
IPQ9554 -- Xiaomi BE7000 (quad-core Arm Cortex A73 at 1.5GHz)
Mid and Low end
IPQ5322 -- Xiaomi BE6500 Pro (quad-core Arm Cortex A53 at 1.5GHz)
IPQ5312 -- Xiaomi BE3600 (quad-core Arm Cortex A53 at 1.1GHz)
kush1979
Hi Trenzterra, can check what is the function of the usb3 port and also can the front display be customized to display for example time. Thanks
Apparatus
USB3 port - Can attach a USB fan to blow at nearby hot devices. Can supply power to the OMADA OC200.
USB3 port - Can attach a fan to blow nearby devices. Can supply power to the OMADA OC200.
Interesting, so you are saying the USB 3.0 port is not functioning other that to supply power to other devices.
This is different from Archer BE800 or Archer BE805.
USB Support
1or 2 USB 3.0
• Supported Partition Formats:
NTFS, exFAT, HFS+, FAT32
• Supported Functions:
FTP Server
Media Server
Samba Server
Apparatus
USB Support
1or 2 USB 3.0
FTP Server
Media Server
Samba Server
I never said it's not functioning. I'm just giving some examples of its use as a USB port
See below post for USB port applications
BoeingWong
Hi may I know what’s the weight of this router? Looking for a wall shelf for this. Thanks
Apparatus
mazza99
With the growing popularity of IoT devices, I have amass up to 70+ clients connected to my Asus Router. Before I switch to Ultraspeed, I wish to know how many wired & wireless clients can the TPLink EB810v support. Does anyone know?
