OnePlus 12 series
fortunecat
Anyone knows how to remove the Google page when you swipe right on home screen?
tkte_85
officially theres no way to remove it anymore with the new OxygenOS, but a "temp" way of doing it is disabling Google app in app management and re-enabling. It will revert back once you restart the phone
petromax
what's the update about ? is it only the Android security patch, or is there any improvement in terms of performance or feature?
oldturtle
those who ordered Black local warranty sets, it will only begin to be delivered to our hands from Thursday onwards.
Veloso
Any good full screen tempered screen to recommend? Curved screen a bit hard to find good ones. Tried those that need UV glue then bake under UV lighting on my previous OP11, works but kinda messy I feel.
awayaway
comes with screen protector applied already. else i recommend smartdevil screen protector from taobao
ayuluv
Yeah am considering tempered glass or screen protector
The stock one scratched already
petromax
I feel the stock one somehow accumulate dust very easily, anyone getting the same issue?
Also, those who ordered green, do you also get green protector case or is it another color?
KeYoKe
Anyone with local set + dual sim can do a test for me?
Check if you disable sim 2, reboot phone, does sim 2 get enabled automatically?
