Prism+ refrigerators
amazingone
I think can use on the 450L ones ..
The 3 ticks one can use ..
Not sure if must go to the company and buy then can use or can use on website ..
prism+ is not one of the participating retailer, cannot use the voucher
treazzzure
The Prism+ fridge keeps making a lot of noise. First time the guy came to my place to fix it. Tt seems like the screw was loose, so after fixing, the sounds went away after awhile. Then this time after about 1+mth the sounds came back again. It is quite loud buzzing sounds. I have 2 fridges beside each other, not touching of course, so I know what is really loud. But the Customer Service this time is telling me it is likely normal, after calling me twice, refusing it feels to send someone down this time. I am very irritated. Be careful, if you want to buy the fridge. Yes, it is cheap, but it comes with its set of problems. First time I thought the support was good, but then 2nd time, it seems poor!!!
articland05
fridge better spend more and buy reliable brands. spoil liao very troublesome
wahlaneh
Dont understand why people go for cheap stuff like tyres, fridges, food etc. Not like they are damn expensive in the first place.
Im not rich but i truly believe in spending more for quality and peace of mind
jack-320
Get cheap stuff so as to have money to spend on holiday or housing loan
86technie
Cuz since they never make it, they will say very good like koyok promotor.
Say this koyok very good in fact no good.
Loud buzzing seems like internal electronics no good.
standarture
Ya lor. Buy one time good one, 10 years easily last.
reno77
I'm almost looking to pull the trigger and get the Purefresh SBS 600 , it's going for $679 with $300 climate voucher offset. It's a Haier 596 rebrand.
Anyone bought and got bad experience with it ?
Mehdi05
i was happy to support a local brand, I bought the PureFresh TMF 530 (Black Inox) on September 5, 2024, and it’s already been nothing but trouble. The fridge spoiled with the same reason on 2 occasions (Not Cold at all) once on February 10, 2025, and again on March 28, 2025. They replaced the parts for the first issue, but for the March 28 Issue they still haven't replaced the parts. I’ve been without a fridge for almost two weeks with no real solution from customer service. They extended my warranty by 3 months and offered me a $79.10 rebate, but they won’t replace or refund it. I’m left with no other options. Of course, i will take whatever $$
I’m sure the fridge give problem again soon, and again once the warranty ends. where I will be charged with Transportaion and sparts fees, extremely frustrated and disappointed
