Wow, If u very productive finish work by lunch, I think the boss will let go home sleep hor?
THIS MAN IS "GENIUS"
today u manually can make 1 car door in 1 hr
tomorrow boss buy machine can make 10 in 1 hr
end of the month they sack 9 of your collegues.
Suddenly u are making 100 doors and still going home at the same time
Where is the rest ?
Read from 10 yr series.
Everything can be solved by productivity
U know wat ? AI & Robotics has the best productivity
AMK GRC. He got dragon shield. Hard to remove him.Which constituency does he belong to ah? I want to laugh at the voters there.
It's the drain...
All productivity gains go to the boss. So what if I work faster and produce more ? do i get more pay or do i get less pay since i now work less hours ?I find his points fully logical. I don’t find any fault. I actually fully agree with him.
He mentioned
1) better training - training to be better at the job and thus, able to complete tasks at speed 10 times faster than without training thus gaining more free time to rest
2) better redesign of job. Instead of 10 people eye power 1 guy changing one light bulb, 1 person manage 10 people to change 100 lightbulbs. If you get my point
3) better equipment. Instead of typewriter, use PC to type. Instead of manual typing to self check, use algorithms to check grammar and spelling mistakes. Instead of sounding rude and bad, use AI to make the writing look 10-100 times better than first draft.
So what’s the matter?
an example:
give you a shovel to dig, vs train and equip you to use an excavator, which option is more tiring to dig the same size of trench?
it's not that complicated, you just don't have the brain power to understand.
siao.. try using the excavator to dig a trench next to gas and electricity pipes
as expected, unable to demonstrate higher level thinking.
in the first place, how were the pipes laid?
nose buttie stopping chiu to use excavator near these pipes and cable.
prease go ahead and utilise chiur higher level thinking
Now he no longer there he is inside selfie bay teamAMK GRC. He got dragon shield. Hard to remove him.
