OnePlus 12 series
tkte_85
For the matte, yes. Do not have the hydrogel rubbery feel. But hardness is lesser than tempered glass but been using for a few years of curved glass phones including flat ones like redmagic 8 and 9 pro.
Japaneko
Thanks! I'll probably get it then next time.
cheangjc
For those want cheap UV glue clear tempered glass can checkout this link on shopee:
https://shopee.sg/3D-UV-Liquid-Temp...tte-Privacy-UV-Glass-i.1201454555.24716997514
I am not afillated/related, just bought 4x and applied myself, quite easy to do yourself. Just have tissues to be prepared to clean up excess glue.
Protip: try to make the phone flat on surface, otherwise the glue will run off the screen. I wasted one uv glue bottle because all run off screen. Also consider taping off the speaker grill area with scotchtape if you want, some excess glue can go in there.
Sauron
Same. Mine arrived today too.
Do you intend to get a protector for the case? The package didn't come with any protector I realized
Huh? Mine has a screen protector applied and a silicon case in the box
coolhead
Ok I better check again. I was busy doing the video of the unpacking and ignore the rest. It did come with screen protector but I may have missed out on the silicon case. Without the case the phone feels abit slippery
tkte_85
If your set is official sg set (same as global sets from other countries), it does not come with charger and case. This is something new from 12 onwards. 11 came with charger but no case. Only CN sets come with silicon case and charger out of the box now
Sauron
I c . Mine is CN
Bardiel
mine got a black silicone like case from one plus. order my tp glass but haven go collection point to take. monday take liao den apply den do finger print security/
junlong602
how's the fingerprint scanner for this? can you unlock it with 100% accuracy? i bought smartdevil tempered glass but it cannot be unlocked reliably even when i registered fingerprint after applying the glass.
cheangjc
Seems to work/same just as good as before. UV glue protector is usually not susceptible to this issue.
coolhead
Mine is green phone hence it probably came with green silicon case.
They already applied a glass protector to the screen
cheangjc
mine is also UV glue. maybe didn't cure well for mine.
Thats why i bought multiple glass protector cheap cheap. In case one dont work, can reapply.
What I did is to make sure glass is very clean and to press with some force near the fingerprint area when applying to thin out the glue in that area.
cheangjc
junlong602
cheangjc
Cannot really tell what type of protector from listing. Got many kind of protector; hydrogel flim, TPU flim UV curing hybrid, tempered glass uv glue, tempered glass adhesive (lousiest on curved).
In any case, just remember to buy more of quantity. Usually the cheapest kind of protector don't have oleophobic coating and ease of install kit, but in return you can get many pcs to try if fail.
Sauron
anyone on GOMO with OnePlus 12? I have been experiencing very slow to no internet connection. But when I switch to SIM2 which is on Singtel, the connection is working fine.
oldturtle
I'm on Gomo 5G, no issues. SG local set.
