Xiaomi TV Discussion Thread VII [consolidated]
KuroI-Kaze
Hey guys
I was using xiaomi P1 43" until my toddler son broke it last week.
I used it for 3+ years and I find the TV excellent for my usage.
Im not sure to get another P1 or if theres a better panel out there today. Please recommend me one.
43~55inch budget $500++
Thank you!
R6exR6
Hey guys
Thank you!
Xiaomi Q2 should be better.
suuhhc
My mi tv 4s suddenly no display, only got sound. Before that no sign of screen problem. Off and on don't show mi logo n still no image only sound. Is it gone case? Only 2 yr + & not heavily used.
abyzab
Anyone has their 58" TV switched on by itself at 5AM ?
My 75in Q1 only switch on the USB every 5am. I have a USB tabletop LED light powered by the USB, that's how I know.
The TV display stays dark.
It turns off the USB/LED lamp in 5 minutes.
I'm wondering if Xiaomi is phoning "home" 😡 like Huawei.
gregory_choo
dont throw the tv away.
connect a buzzer to the usb port.
it will sound everyday at 5am.
still good as an alarm clock.
lasnoblur
bought the 65" Q2
i noticed that after a day not using the TV, when i try to switch it on, the led indicator at the bottom would light up, but the screen is not powered, i need to turn it off and on again then the screen is powered
after that if i off it and turn it on in short 30min intervals, i don't observe this issue
anyone encounter the same before?
Had this problem when the tv first arrive and im not familiar with it. i thought is battery problem on remote.
Turns out that the start up could have few sec delay. Wait for indicator light at TV bottom first. then tv screen would appear, be patient abit with this tv.
Preacher1010
Recently bought the 43in 4K "A PRO" series from Shopee, few weeks ago.
Anybody has this issue where, from LiveTV mode, the TV just switches to Google Home menu by itself?
KuroI-Kaze
i got the xiaomi Q2 55inch in the end ..
delivery seem slow, 1 week no sound from them
i got it from lazada altho got say is pre-order will take up to 30days but hmmm
purplesnow
Hi, is there play controls to enable for Xiao mi tv when playing video files from usb hard drive. Found that when playing video files from usb hard drive there is no button to go to next file have to press back and then select the next file.
suuhhc
That's what I did too if need to skip to next video, no direct button. Its rewind & fast-forward also not user friendly, just a press will RW/FF ~1 min :(
