Thoughts on PC build choices
RahkeidD
Looking to get a custom built PC, putting it out there I'm not that good with parts compatibility and all those. So just wanted to get some thoughts on the following builds
1. InvaderPC
AMD RYZEN 9 7950X3D 4.2GHz 16CORE/32THREAD
ASUS TUF GAMING X670E-PLUS WIFI AM5 ATX
COOLER MASTER MASTER LIQUID 360L
CORSAIR VENG RGB DDR5 AMD EXPO 6000MHz 32GB
GIGABYTE GeForce RTX™ 4090 WINDFORCE 24GB TRIPLE FAN
WD BLACK SN850X 2TB GEN4 7300MB/s NVMe M.2
SILVERSTONE HELA 1200R-1200W PLATINUM ATX3.0 PCIe5
LIANLI O11 DYNAMIC EVO RGB BLACK TEMPERED GLASS ATX CASING
10 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 6 + BT 5.2
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
WINDOWS 11 HOME OEM x 1
PWP MONITOR:
Gigabyte GS32Q Gaming Monitor x 1
RAM UPGRADE 6:
CORSAIR DOMINATOR PLATINUM RGB DDR5 AMD EXPO 6000MHz 64GB(32GBx2) CL30 KIT x 1
ADD ON SSD:
Samsung 990 Pro 2TB Nvme 2.0 7400MB/s M.2 x 1
ADDITIONAL WARRANTY:
3 years desktop parts warranty(onsite pickup and return) x 1
MONITOR ADDON:
GIGABYTE M32U-EK 4K UHD 10BIT IPS KVM GAMING MONITOR x 1
MOUSE:
RAZER DEATHADDER V3 PRO FAKER EDITION LIGHTWEIGHT WIRELESS MOUSE x 1
MOUSE PAD:
INVADER XXL MOUSE PAD x 1
RAZER KEYBOARD:
Razer BlackWidow V4 Pro RGB Mechanical Gaming Keyboard x 1
UPS:
APC EASY UPS BVX1200LI-MS 230V 1200VA/650W AVR BACKUP UPS x 1
SLEEVE EXTENSION CABLE:
Invader PC White Sleeved Extension Cable Kit x 1
COOLER UPGRADE 3:
CORSAIR iCUE H150i ELITE LCD XT 360MM RGB AIO x 1
MOTHERBOARD UPGRADE 7:
ASUS ROG CROSSHAIR X670E HERO AM5 ATX x 1
POWER SUPPLY UPGRADE4:
CORSAIR AX1600i-1600W 80+ TITANIUM x 1
THERMALPASTE:
CM CRYOFUZE VIOLET THERMAL GREASE x 1
RGB CABLE:
CREEPER PCIE 5.0 - 12vhpwr- x 1
2. InvaderPC
INTEL I9-14900K 3.2GHZ 36MB CACHE
ASUS ROG MAXIMUS Z790 DARK HERO
LIAN LI GALAHAD II LCD 360 BLACK ARGB AIO
G.SKILL TRIDENT Z5 RGB 7200MT/s 32GB(16GBx2) CL34
ASUS ROG STRIX GeForce RTX™ 4090 O24G GAMING
PHANTEKS NV7 BLACK DRGB TEMPERED GLASS E-ATX
9 X PHANTEKS D30 120MM D-RGB FANS
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
PWP MONITOR:
RAM UPGRADE 7:
G.SKILL TRIDENT Z5 RGB BLACK 6400MHz 64GB CL32(32GBx2) KIT x 1
ADD ON SSD:
MONITOR ADDON:
GIGABYTE M28U-EK KVM GAMING MONITOR x 1
MOUSE:
MOUSE PAD:
RAZER KEYBOARD:
UPS:
FAN UPGRADE 4:
9 X LIAN LI UNI FAN TL LCD 120 RGB BLADE x 1
THERMALPASTE:
RGB CABLE:
CREEPER ATX 24PIN ARGB Cable Pro x 1
or Mansacomputers builds
1.
Case: NZXT H9 Elite - White
Processor Brand: Intel Core Processor
Processor: Intel Core i9-14900K
Motherboard: Asus Z790 ROG Maximus Dark Hero Wi-Fi & Bluetooth (DDR5)
Cooler: NZXT RGB Kraken Elite 360mm (LCD) - White AIO
Graphics Card: Nvidia RTX 4090 24 GB - Asus
SSD: Samsung 990 Pro 2 TB Gen.4 - R:7400/W:6900
Additional SSD: Samsung 990 Pro 2 TB Gen.4 - R:7400/W:6900
HDD: Toshiba 6 TB HDD
Ram (DDR5 Intel): G.Skill Trident Z5 64 GB DDR5 6000 MHz
Power Supply: EVGA SUPER NOVA 1600 W 80+ Platinum (Full-Mod)
Operating System: Activated Windows 11 Home 64-Bit
RGB Fans: Lian Li Uni Fan SL120 V2 (6 RGB Fans)
RGB Lighting Strip: RGB Lighting Strip
Custom Sleeved Cables: Lian Li Strimer V2 Sleeved Cables
Monitor: AOC 34" CU34G3S 2K QHD 165 Hz VA Curve
2.
Motherboard: Gigabyte Z790 Aorus Pro X Wi-Fi & Bluetooth (DDR5)
tigerwoods
1. InvaderPC
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
PWP MONITOR:
RAM UPGRADE 6:
ADD ON SSD:
MONITOR ADDON:
MOUSE:
MOUSE PAD:
RAZER KEYBOARD:
UPS:
COOLER UPGRADE 3:
THERMALPASTE:
RGB CABLE:
2. InvaderPC
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
PWP MONITOR:
RAM UPGRADE 7:
ADD ON SSD:
MONITOR ADDON:
MOUSE:
MOUSE PAD:
RAZER KEYBOARD:
UPS:
FAN UPGRADE 4:
THERMALPASTE:
RGB CABLE:
1.
2.
Dont get a AOC 34" CU34G3S 2K QHD 165 Hz VA Curve
Get at least a IPS 34" monitor or 34" oled monitor, it's a waste to spend so much money on a high end pc and use it on a cheap VA monitor, VA monitor has bad smearing and ghosting, i know bcos I'm using a 34" ultrawide VA monitor.
NightRaven49
i would say the 4090 is not worth buying so soon to the next gen of gpus, rumours are pointing to year end release of 5090, so q shag to buy 4090 at still inflated prices now and be dethroned within the next 6-9 months. also do share ur use case and monitor resolutions.
RahkeidD
Honestly currently just going for one thats going to last me for the next few years at least, its fine with the gpu being dethroned in the coming year. Currently because my setup is pretty much between half dead and working, so looking to get an upgrade at least to the current top.
Usage would mainly for gaming, while multitasking casual. Monitors currently using prism 2560x1080 or somewhere there,currently outside so not quite sure. Tentatively just checking which of the choices would be best to go for, invaderpc including dual monitors with mouse and keyboard whereas mansa would only include 01 monitor.
Like i said, I am not that good in terms of compatibility and other more in depth issues so just wanted to check here for any big issues before choosing 1 to go for or other choices.
And yes I know buying parts and building myself is more cheaper, but not much time and I am kinda clumsy with electronics.
NightRaven49
u will not need a 14900k + 4090 for this.
generally if u buy from prebuild companies, should be no compatibility issue, surely they dont want to sell a pc with incompatible parts :s22: i would recommend u look at something like the 7500f + 7800xt for around 1.5k from invader that should last u quite a while. and thats actually a pretty good deal, diy cannot match.
Yongkit
I think TS not worry on the budget of the build but more like how to utilize the system for gaming. the high end components probably will be under utilized but it is a want more than what the system can be utilized.
RahkeidD
True ^ , pretty much just looking for a high end one with budget possibly within $10k. Just hoping it doesn't end up with my current one from Aftershock that ended up sending for servicing for 4 times or so within 2 months, telling them the issue and how to reproduce the issue
RahkeidD
Thanks for the information, but probably just trying to make full use of the bonus I'm probably getting, before I spend it anywhere else on games that might not even last as long as the pc
NightRaven49
then in that case u have nothing to worry about, just go ahead. pc parts generally have good compatibility nowadays, and u still have technical support if something goes wrong.
RahkeidD
So probably just go for the invaderpc ones? If so, would you recommend the AMD or Intel one? The other parts are about the same I think?
