- Nov 27, 2000
Only way is to get a simba line and test it urself... nobody will know what speed you'd get.I don't need high speed. We don't do gaming. Around 10mbps stable speed is what we want.
Believe most telco limit up to 4 max, so SIMBA should be the same.anyone knows how many number can i sign up for simba?
i am currently using giga and i have four numbers which i intend to port over to simba.
thx
Giga is postpaid, prepaid is only available under ST, SH, M1 & SIMBA.i am still dumb abt this post or prepaid…
i believe the giga is prepaid
is the simba $12/ mth also prepaid?
It works but not for intensive usage, stability depends on area and users, definitely cannot compare with broadband plans.I am also curious if anyone has tried mobile hotspot using Simba and cancelled their home broadband?
I have M1 500mbps and I have been waiting for M1 to drop their broadband prices to match with Simba/Whizzcom. But since they haven't, I am considering just cancelling the M1 broadband and living with mobile hotspot for sometime.
Then if it becomes frustrating using hotpot, I then subscribe to the Simba 2.5gbps annual plan. It takes about 12 months to break even due to the 1 time costs of NLT+activation. After that you start savings
I just tested. 7.89mbps d/l 1.5mbps u/l ping 60ms. I give up.Only way is to get a simba line and test it urself... nobody will know what speed you'd get.
Yes, as recently Giga facing BE issues with their systems that lasted a few days.went to a simba shop
and the staff said many with giga had issues porting over to simba
Believe there's a grace period of 30 days, which thereafter will be terminated.Mine is sim only 100gb plan. What if I don't top-up $10 to the wallet before end of 1st month? Will my plan terminate automatically?
Weekly I used to top-up my MRT card via SimplyGo while in JB & had no issue getting SMS OTP.I can't receive OTP in Beijing.
Anyone having issues with receiving OTPs regardless where he/she is?
Want to change my plan. Day 25 today. Sianzzzzz
Is that for both postpaid and prepaid?Believe there's a grace period of 30 days, which thereafter will be terminated.
Circles Flexi isn't available to be ported to at all?Is that for both postpaid and prepaid?
I want to port out of this SIM to Circle Flexi and then upgrade the circle Flexi to the $5 20gb plan.
Or you looking to port SIMBA to replace Circles Flexi and then upgrade to $5/20GB?
I just received my new SIM card and the plan is SIM only 100gb. I would like to know if I don't top up $10 before 30 days, what will happen?
Is there a grace period or will my number get terminated immediately?
Also I wish to know if my plan is prepaid or postpaid?
Can I port out after the 30 days to another postpaid Telco and retain my number?
Go to this url and click on the link relevant to your plan to know all the details:Mine is sim only 100gb plan. What if I don't top-up $10 to the wallet before end of 1st month? Will my plan terminate automatically?
You need to pay and keep your line in service to be able to port out.Originally my number was Starhub Prepaid. Circles flexi is available for porting, but first I need to convert my prepaid to postpaid. So I ported to simba. But I also need to wait for 30 days on Simba to avoid the port out fee.
I just sent out a support ticket to Simba:
So either wait for 2 months in total, or pay $30 port out fee.
Dear Customer,
Thank you for contacting SIMBA Customer Support.
Upon checking, your port-in request is successful and your SIM-Only 100GB for 8xxxxxxx is activated and its under postpaid account.
Please be informed that you have 21 days from the time the new billing cycle starts to renew your mobile plan before the system automatically terminates your mobile service.
Should you need further assistance, please do let us know. Have a great day!
Kind Regards,
Jxxxxxx
Customer Experience
https://www.simba.sg/cis
simba’s signal and coverage is more consistent, but m1 is faster (if it works)hi is SIMBA's reception good? cant stand M1 anymore. finding an alternative
