TP-Link EB810v - Quick overview
nuts
Would like to share that I am using a Lenovo Yoga PRo 7 14AHP9 with the RZ616 Wifi 6E chipset and also can't see my Wifi 6 network.
Apparatus
If your laptop is far from the router and blocked then 6GHz signal won't be good
Move your laptop nearer to the router
SojIrOu
Have you tried latest drivers/firmware to see if it unlocks 6GHz? Otherwise the only other option would be to change the country of the WiFi card.
Strangely, my desktop is using RZ616 (mobo manufactured in Oct 2022) and laptop is Yoga 9i 14IRP8 with AX211 bought in March 2023 and both were able to use 6GHz before it was approved.
Edit: Just to confirm using Windows 11? Some mentioned Windows 10 not supporting even with new drivers for other WiFi cards.
trenzterra
How do you change the country of the wifi card? Tried googling but can't find anything lol. My X13 with AX210 right next to the Yoga Pro 7 so can't be signal issue. Both using w11. My S23u also no issues
SojIrOu
Seems like what I read about changing country was relevant to Linux instead of Windows. The only thing that may be relevant is the location settings. If it is off on your laptop, try turning it on to see if it allows your network card to enable the frequency.
Otherwise try updating the firmware and driver to see if that can solve the issue. You may need to completely remove driver via device manager first (download new drivers first otherwise you need to connect via wired).
https://community.frame.work/t/resp...ard-doesnt-work-with-6ghz-on-kernel-6-7/43226
https://superuser.com/questions/1759511/why-is-the-6-ghz-band-not-working-with-my-wi-fi-6-card
kimsix
new beta be800 firmware added back ofdma + mu-mimo.
mumio is missing also in SH variant as shown in post #64
more importantly TPlink may finally sexposed the 2GB ram in this firmware :o
16 hours ago their forum admin gpgt her web gui, down to 28% memory usage!
https://community.tp-link.com/en/home/forum/topic/666236?replyId=1354772
SH users lets bug them to release new eb810v firmware asap! enable mu-mimo + 2gb ram!
@Michael87,
I believe that the original firmware that was posted has since been officially given to models due to the other fixes and performance increases. Our team has provided another test firmware that will help with the mu-mimo setting being disabled with some devices:
BE800 v1: https://static.tp-link.com/upload/b...8/BE800v1_1.99.97(1.1.1)_240417_userdebug.zip
kimsix
Eaststander
On the consumer router side, Asus probably has the best features. On the other hand, Asus router will usually be more expensive.
For example, top of the line Asus ROG GT-BE98 WiFi 7 router will have the following.
1) VLAN and Guest Networking Pro
2) Wireguard VPN Server/Client
3) No SFP+ port. Only 10G WAN/LAN + 10G LAN.
4) It has built-in OOkla SpeedTest but the CPU is too weak to handle 10Gbps (or 8.2Gbps)
5) Need to wait for testing reports and may need future FW update to support MLO and AFC
6) 10G WAN/LAN + 10G LAN. The 10G WAN/LAN port can be configured as either WAN port or LAN port. But for 10Gbps plan, it will be used as a WAN port.
Brothers, I just replaced my poor Nokia for the Tp Link on a 10gb Ultra broadband plan. How are you connecting the fibre as I want rid of that pool nokia ONR box which currently takes in the fibre. Also I need extra 10gb ports so if I use the 10gb port as a WAN port how do I get extra 10gb ports for my network which is 10gb?
1) If you miss to get the super admin password during the installation, you are stuck with the unbridged Nokia XGS-PON ONR. It is not possible to replace the Nokia ONR as of now.
FTP -- Nokia XGS-PON ONR
XGS-PON ONR 10G LAN port -- 10G switch (existing or new) -- your 10G home network
2) If you have gotten the EB810v, then you can use the following configuration.
XGS-PON ONR 10G LAN port -- EB810v as AP
EB810v 10G LAN port -- 10G switch (existing or new) -- your 10G home network
Or
10G switch (existing or new) -- EB810v as AP
Spongy
I am having DNS issues with SH and tried to change it on the router. This has resolved connection issues with my laptops but my phones and TV still cannot connect to the internet. Can any expert advise if I am doing it right or how should I proceed please?
seowbin
trenzterra
Need to set IPv6 also I guess
willy792003
A little disappointed with the range for EB810V. The AX3 Pro can reach the furthest end of the house (HDB 4-room) easily, the EB810V connection can drop off or very poor speeds (2-3 bar on my phone).
Same here, very disappointed with the range. It advertised as having 8 antennas but worse than my previous router with only 6 antennas.
What's the most cost efficient EasyMesh device that I can pair with this router? WiFi 6 will do as I don't have any WiFi 7 devices
TP-Link EasyMesh FAQ
https://www.tp-link.com/sg/support/faq/3529/
Cheap and not bad may be TP-Link Arch AX72, arouns S$80 BNIB from Carousell, dumped by M1 users.
Can use Deco mesh, since from TP-LINK?
Deco is not compatible.
